Thread: Cushion fwd frame - radiatorsupport ??
    Default Cushion fwd frame - radiatorsupport ??
    Can You advice me where to find a set ( 2 pcs) of these cushions that can replace the old rusty ones ?
    1994 Chevrolet K1500 Silverado
    1989 Buick LeSabre Estate Wagon 6,5l Diesel + THM 700r
    Hi
    Those body mounts do look a bit sad,
    This outfit has good stuff. I have ordered from them several times.
    http://www.classicparts.com/
    You can look up what you need and order it online.
    Here is a second place I have used
    http://www.google.com/url?sa=t&rct=j...44342787,d.cGE
    Hope this helps
    Robyn
    www.lmctruck.com is also a good source. Int'l shipping is going to be your biggest issue, so your options may be limited. The body mount bushing sets are not that uncommon, and should be available through any local collision (crash) repair shop. I have a bunch of them around, taken off of a 1995 GMC K1500. I can make those available, if all other options fail.
