Results 1 to 6 of 6
Thread: 96 K2500 Transfer Case Switch?
    Jul 2001
    Windsor,California
    Default 96 K2500 Transfer Case Switch?
    Can the Transfer Case Switch that supplies power to the Front Axle Actuator be replaced without dropping the Transfer Case and where is said switch located? Also, does AC Delco offer the replacement switch and what is the correct p/n for a 96 K2500 Pickup 8600 GVWR? Rock Auto only lists a Dorman as available, a 2-pin p/n
    600506 and a 3-pin p/n 600502
    1996 Silverado K2500 ECLB 6.5TD - 4L80E - 4.10 Diff
    Diamond Eye 4" Turbo-Back Exhaust
    Flowmaster Downpipe + Crossover Tube
    Lubrication Specialist SS Oil Cooler Lines
    9 Blade Fan and JK Fan Clutch
    JK Quick Heat Glow Plugs
    Heath PMD Isolator System
    Racor 645 Fuel Filter
    PML Deep Trans Pan
    Amsoil ATF
    K+N Air Filter
    Bilstein Shocks
    PYO Alloys
    Feb 2012
    Pauline, SC
    I'm not sure about the right part ## but if you aren't sure you could purchase a "posi-lock" cable.... it installs without much work and when ya need 4x4 just pull the cable... mine would take forever to lock when the weather is cold, now I just pull the cable and go....
    1993 Chevy K3500
    like us on Facebook
    Jul 2001
    Windsor,California
    Ordered the TCS off eBay for $10 - will R&R it next week and see if I get my 4WD back.
    PML Deep Trans Pan
    Amsoil ATF
    K+N Air Filter
    Bilstein Shocks
    PYO Alloys
    Did you get the correct switch? I had to change cases and the one I have now uses a TCA4 (3 wire long stem #15693423) and the original case had a TCA26 (2wire short stem).
    I am looking for a 2 wire long reach if they make such a thing.
    Jul 2001
    Windsor,California
    I'm hoping I bought the right one as I got the 2-wire. It's supposed to be here today so guess I'll find out when I pull the old switch off .
    PML Deep Trans Pan
    Amsoil ATF
    K+N Air Filter
    Bilstein Shocks
    PYO Alloys
    Jul 2001
    Windsor,California
    Found some more detailed info on nalleygmc.com - I searched based on a 96 K2500 and here's the p/n's that came up. Still looks like I wont know til I have the bugger off the truck as the info shows both p/n's working with either the 4L80E Auto Transmission or the 5 spd Manual but my bet is it's the 3-wire
    2-wire p/n 15582030
    SWITCH,TRFER CASE SEL(TYPE 241C)(PART TIME)(2 PIN CONNECTOR)(ON TRANSFER CASE). Required: 01
    For: K1,2 (1992-1992) (1992 - 1992).
    For: K1,2 GETRAG 5-SPD M/TRANS(MG5),4-SPD A/TRANS(MT1),5-SPD M/TRANS(MT8) (1993-1993) (1993 - 1993).
    For: K1,2 GETRAG 5-SPD M/TRANS(MG5),5-SPD M/TRANS(MT8) (1994-1994) (1994 - 1994).
    3-wire p/n 15693423
    SWITCH,TRFER CASE SEL(TYPE 241C)(PART TIME)(W/3 PIN CONNECTOR)(LOCATED ON TRANSFER CASE). Required: 01
    For: K1,2 4-SPD A/TRANS(M30) (1993-1993) (1993 - 1993).
    For: K1,2 4-SPD A/TRANS(MT1),(M30) (1994-1994) (1994 - 1994).
    PML Deep Trans Pan
    Amsoil ATF
    K+N Air Filter
    Bilstein Shocks
    PYO Alloys
