Results 1 to 6 of 6
Thread: diesel convertion for 69 chevy truck
    Aug 2004
    JC TN
    Post diesel convertion for 69 chevy truck
    Im thinking abought converting my 69 blazer to a diesel engine witch engine would you sugest a 6.2 6.5 or other?
    Thanks Earl
    turbovair Guest
    Talking
    Given the choices, I would opt for the 6.5 TD.Choose a pre-electronic model for swap simplicity.Go big. The work during the swap will be just about the same. Get as much displacement and horsepower/torque as you can.
    NH2112 Guest
    I'd go for something really off-the-wall, I mean if you're going to do something different do something different. There's always the "4-cyl Cummins from a bread truck" route, those are still rare enough to be interesting. A friend fabbed a Leyland (I think) diesel, complete with compression release, into a mid-70s F100 which may have involved more fabrication than you're up for but it's still doable. I still have plans for my Volvo TD60, but I'm not sure if it's going into my stripped K10 or if I'll look for a 89-93 Cummins Ram in order to have something already set up for the diesel, as far as weight goes.
    Something else I'd like to try sometimes would be an air-cooled Deutz, just for the uniqueness factor
    Aug 2004
    JC TN
    I was thinking a 6.2 or 6.5 they are esy to get how does the 4cyl commings comparie in power and are there any aftermarcket performancs upgrades for it.
    NH2112 Guest
    From what I understand 250HP is well within the range of possibilities for a 3.9L Cummins, and many of the performance upgrades for the 12-valve 5.9L Cummins will work with the 3.9L. It's a heavier-duty engine than the 6.2L/6.5L and will last longer, especially if you keep it in the middle of its range (around 150-160HP.) As far as getting them, the easiest way will probably be to find out who buys the old bread trucks in your area and parts them out.
    Aug 2004
    JC TN
    Using the 3.9 can I keep my 700r4 trans Its new and custom built to handdel the extra HP and TQ I have it be hind my 383 now and It doesnt have any problems so I would like tokeep useing it if possible.
