06 LLY - Bad Head Gasket?
While towing yesterday, I was heading downhill with the grade braking humming along (~3,800 rpm), like I've down many times before.
Then I notice a smoke screen coming from the truck, and within several seconds the 'low coolant' light appeared on the DIC. I couldn't really pull over easily, so I limped to the next exit and now I have a steady stream of coolant dripping down, basically in line with the turbo/bellhousing.
I can't find any visible ruptured hoses/line from above - the only place I can see the drip coming from is from the right rear corner of the passenger head. I can't tell if it's coming the gasket itself or above it?
Any other possible source from above? I thought when the head gaskets fail they typically pressurize the cooling system rather than create a outside leak, especially one as bad as mine is.
Hoping it's something more simple I'm overlooking, but...
Thanks.
Joe.
2006 Chevy K2500 LLY Duramax/Allison Crew Cab!
1996 Chevy C2500 6.5 auto Ext. Cab LB
