I kept the origanal tank in mine, just removed the old 5/16" return line and opened it up and put a 1/2" steel tube down through it. And if you get EFILIVE you can re-calibrate the fuel guage to work with your existing sending unit. I persoanlly kept my 95 cluster to avoid many of the associated tasks that came along with swapping the cluster.
