2003 electrical gremlins
My 2003 sat for a few days hooked to the camper. When I went to move it, it barely started, i assumed I had left the cable hooked and the camper had drained the truck batteries some. I looked and I had actually pulled the plug. I let it run a bit to help batteries.
Next day (today)I tried to start it and it did not have enough power to spin it fast enough to start it. I put a charger on it and a few hours later it did start normally. After it was running, I noticed that the full tank of fuel said empty, it showed no volts, no oil pressure and no movement of any temperatures. I shut it off and watched a bit closer when I started it again. All the gauges dive lower to the left while cranking then as it is running they go back to "e or 0".
I shut it off again and as I was exiting I realized that the radio did not shut off. No sound from speakers but the face is lit.
More looking shows that the electric locks and windows do not work at any time, key on or off,doors open or closed. The gear selector indicator and driver info window seem to be normal. The HVAC head unit seems normal and the fan works thru the speeds. I noticed the ABS light is on, The battery light is on and even though there is no fuel shown on the gauge, the low fuel warning light goes out after the truck starts.
I cannot seem to find a blown fuse either under the hood or to the lower left of steering column.
So any Idea of where to look? Maybe for a bad ground, but where are those connections hid on a 2003?
Thanks for any help.
Reason: add info
