Thread: OK, I Did It
    Maplesville, AL - Home Base
    Default OK, I Did It
    Back in February-March 2016 I changed my fuel filter. I specifically remember making this change since the water sensor module had to be replaced (it was original) since one of the two electrical leads broke off. Now 8 months later:
    I had noticed over the previous several days my engine turned over a bit longer than normal mainly on the first start of the morning. I initially thought this was just due to the cooler weather, but then 2-3 days ago while driving on the highway when going up a small hill I felt a momentary reduction in power. It was only for a second so that got me to thinking fuel filter. The filter has been in service since February-March and was right at 10,000 miles when I replace it anyway so I thought I would do it in a day or two. Yesterday morning again the first start was a bit longer cranking than normal, but not terribly excessive - 2-3 seconds vs 1-2, but definitely longer. I left town and on the first small hill I experienced a power loss for 4-5 seconds vs just momentary as a few days earlier. Now I'm thinking definitely filter time when I get back home.
    Arrived back home after the 30 mile round trip drive and got to work with the filter change. I have owned this truck since new and this was my 17th filter change so I know the routine well. When I was putting the filter wrench on the filter after removal of the sensor wire the filter turned just a tad. What is this? Yep, the filter was loose enough to turn by hand and easily. I think I found my fuel starvation problem. When I removed the filter it was only about 1/3 full of fuel. Yep, problem found and I'm the guilty party. Installed the new filter and problem now fixed. I did tighten the new filter until good and snug this time. I'll let you all know if I tightened it too much when I have to change it again and the profanity starts.
    I hope all you veterans had a great Veterans Day and Thank You For Your Service.
    Ed
    KM4STL
    Don't be so hard on yourself. 1 in 17 is a pretty good record. And, they can loosen/tighten themselves over time/miles for many reasons, and there's a fine line between tight enough and too tight.
    Sounds like you had an easy fix.
    My general rule is: if I can get a 2-hand hold, I'll just use my hands to snug the filter. On the other hand, if I can't get a good 2-hand hold, I use a filter wrench to put a little more on it. And, I always uses a little motor oil or grease on the seals, to help the seal and to make the filter easier to remove later on.
    The 2 hand tighten is what I do too, but I did this in March and it was cold so maybe my 2 hand grip wasn't what I thought it was or maybe my hands aren't what used to be. Either way, I used the wrench this time and put another 2-3 degrees max. Just a hair more than 2 hands.
    Ed
    KM4STL
