Manual Glow Plugs w/ OBDII
Does the PCM throw a code if the OEM glow plug relay is activated manually?
If that's a problem, couldn't you set up a separate relay to independently power the glow plugs with a push button?
I'd think the very common Ford starter relay would handle that amperage load OK. The same relay type that Robin suggested on the recent starter thread.
1995 K2500, 8600 GVWR, 6.5TD, NV4500, 3.73:1, 18:1, balanced, Fluidampr, DSG timing gears, '97 cooling upgrades, 2100 psi-pop injectors, 4" exhaust, ceramic coated exh manifolds/turbine housing/SS crossover pipe, Autometer: pyrometer, boost, oil temp, oil press, fuel press, & water temp gauges, remote oil filter, B&M plate-style oil cooler w/ braided SS oil lines
