Results 1 to 8 of 8
Thread: cooling system high pressure and losing coolant
    Apr 2017
    Sparta MO
    Unhappy cooling system high pressure and losing coolant
    I have a 2002 Chevy Silverado with 6.6 Diesel LB7. Have excess pressure in cooling system , losing coolant, does not over heat. I also had a oil test done for coolant in oil, none found. Tested coolant for exhaust neg results. I am leaning towards headgaskets or a cracked head. Any ideas out there?
    Dec 2000
    Hawaii/Arizona
    If you are loosing coolant in small amounts over time and not over heating I would suggest replacing the coolant pressure cap. They are inexpensive and a good starting place to look for the cause. My 2006, LBZ was using small amounts of coolant for several years and a new pressure cap solved the problem.
    Good luck
    John
    *2007 Pontiac Solstice.
    A typical cooling system will reach a pressure of 8-10 psi at operating temperature. After sitting overnight and the engine cools completely, that pressure should drop to near zero. A cooling system that holds significant (a few psi) pressure overnight indicates a problem with combustion pressure finding its way in to the cooling system. Jim
    May 2012
    Langley
    I had something similar for a while. I bought a new cap and I also had a collapsed upper rad hose.
    Seemed fine for awhile, then had additional issues.
    Eventually (over a couple of years) it lead towards head gasket failure
    Hopefully yours goes somewhere else!
    Jan 2006
    South Milwaukee, WI
    Hope you got 'er fixed by now but man, this sounds really familiar. About 2 years back I had the same thing with an '01 LB7 and it turned out to be a leak at the #7 cylinder- bad head gasket. And this, after a new set of head gaskets that were replaced about a year earlier. I took Kennedy's advice and bought a set of studs- no more OEM head bolts. And no further leaks.
    "Chessy56"
    So. Milwaukee, WI
    '01 2500HD, LB7, ~440K miles
    Winston Churchill
    Quote Originally Posted by chessy56 View Post
    ... I had the same thing with an '01 LB7 and it turned out to be a leak at the #7 cylinder- bad head gasket....
    How many miles did the engine have on it - with head bolts - before the head gasket failed the first time?
    Jan 2006
    South Milwaukee, WI
    The first time it failed, I had ~338K miles on it. I saw leakage from below around the #1 cylinder. It hadn't totally failed yet, but the evidence was clearly indicating a leak was in the making (it had the original head bolts). The (2nd) leak was at the #7 cylinder and it occurred at ~401K, less than 2 years later. It now sits idle with ~437K miles on it. I had studs installed during the 2nd HG replacement.
    "Chessy56"
    So. Milwaukee, WI
    Winston Churchill
    So, 338K miles on the original head gaskets and original Torque-to-Yield (TTY) head bolts... Sounds like good service to me. Properly prepping the head and block deck surfaces during a head gasket replacement is important to long-term reliability.
