hmmm.
I'm not really sure if I can get a trailer to tow now.
If I do a diesel swap, I want to figure out everything I need.
I'm worried about a transmission. Not sure what will fit, or work. I'm not sure if I want automatic or stick. Its a stick truck now, so would I be able to retain all the pedal and stuff now? I got the rear end figured out. I'm going to use a 4x4 94 up i think ford explorer posi rear.
I would like to use a four cylinder, because its not as heavy (don't think so at least)
Id like to turbo it aswell.
I'm thinking if I were to do a V8 diesel it would be a 6.2 with 6.5 or homebuilt turbo setup.
theres alot of things I'm not 100% sure about.
Went to the NADP August blackout. I love the power that diesels put out, the turbo spooling, the smoke, the noise. I would love to have a diesel in my truck.
A Toyota diesel would probably a decent setup. Toyota engine, and whatever transmission will fit that. I'd definitley want a turbo.
Found a 1L toyota diesel in Calgary, with trans but trans needs to be rebuilt. Comes with mounts, rad, intake, wiring, glow plug gear... might buy it..
