Results 1 to 12 of 12
Thread: Speedometer bouncing
    Mar 2010
    Default Speedometer bouncing
    My 94 GMC K2500 Suburban the speedo is acting up . Its wont work right , or its bouncing all over the place and then sometimes it just stays on 0 mph
    Anyone have any ideas on where to start chasing this down ?
    Thanks Brian
    1994 GMC 2500 6.5LTD 4wd
    Marine injectors and built 4911 pump to run veggie oil
    1981 Toyota 22L Diesel Pickup
    Check your plug going to the sending unit on transfer case. If it is good go ahead and pull sending unit to see if it is full of filings on the bottom end.
    Might check connections at VSB too. Pull glove box out and it will be a white plastic box about the size of a cigarette pack just left of the opening where the glove box was.
    Dec 2000
    Hawaii/Arizona
    If it is cable driven remove the cable from the back of the speedometer. Put some wheel bearing grease on the tip of your finger and put it on the cable behind the speedometer and put it back on to the speedometer snug. If the cable is loose at the back of the speedometer it causes the needle to jump around. If it is electric check for a bad ground or bad sending unit.
    Good luck
    John
    *2007 Pontiac Solstice.
    Quote Originally Posted by CoyleJR View Post
    Good luck
    John
    94 is electronic not cable driven.
    Mar 2010
    ok thanks ill give that stuff a try this weekend ....
    Lubbock TX, USA
    Sounds like speed sensor, wiring, or VSSB/DRAC Module behind glove box near the PCM.
    If you need a new VSSB you can get one at www.uniquediesel.com/drac
    Thanks,
    John
    1986 C10 SCLWB 6.2TD 3.73 700
    1989 V20 SUB 6.2NA, 3.73 400
    1994 G20 VAN 6.5NA, 3.42 60E
    1996 K30 DRW 6.5TD 4.10 80E
    Dec 2000
    Walla Walla WA
    I had a similar issue. Turned out to be the male plug connector on the rear pickup. It was removed previously by someone who had the tranny replaced. Probably yanked on it to hard and broke one of the two arms. Was inserted but not tightly which led to sporadic speedo bouncing around.
    Mar 2010
    Ok ive cleaned the plugin on the transfer case and pulled it and cleaned the sensor . I will try the box int he dash next . Are these boxes the same on the gas trucks and burbs of the same body style ? if so i may goto my local pick n pull and get one . those new ones are pricey
    Thanks Brian
    Little white case just inside the dash. Pull glove box and its in the lip of the dash to your left. About the size of a cigarette pack.
    Mar 2010
    Anyone know if the little white box on these are the same on the gasser trucks and burbs ? I took the one out of my 94 Chevy 1/2 ton with a 305 and I'm still getting the same thing . I may try taking the sensor back and get a warranty one and try that before i invest in a new box
    Thanks Brian
    Can't remember if it was bouncing or just quit all together on my 94. But it was filings built up on sending unit in transfer case where it reads the reluctor wheel. Just pull it out and see if its all covered in metal.
    Mar 2010
    I will have to try and pull it and clean it . I tried that when i first posted and it didnt seem to do any good . Ill clean it and if it dont help ill replace it
