Hi Guys,
I'm in the process to swap my 4l80e in my 84 Suburban behind 6.2l Diesel.
I mount a tps via custom made adapter at the IP in place of the original tpswitch.
Now, I need an engine speed signal, too.
The hole time I thought, it will be easy, because I wanted to use a trigger- or reluctorring from the 6.5l engine with original engine speed sensor und original front cover with ess-opening. Now, it seems that there is NO chance to get that reluctor ring somewhere.
Is that right? Or did I overlooked something?
Btw, is the 6.5 camshaft similar to the 6.2 camshaft in that area, where the reluctor ring and harmonic balancer sit?
How did other guys get the ess from the 6.2l to use it for electronic shifted trannys?
Greetings Marco
