While looking for another problem (found a locked up u-joint), we had the rear of the truck in the air. Doing a routine wheel bearing check we noticed a lot of play in the left side spring. We even took the shock off to make sure that was not the issue. About 1/2" of motion that is not present on the other side. Could not find a broken spring. Is this something to be worried about?
