Thread: 4l80e swap behind 6.2l Diesel. need engine speed signal
    Aug 2013
    Germany, Berlin
    Default 4l80e swap behind 6.2l Diesel. need engine speed signal
    Hi Guys,
    I'm in the process to swap my 4l80e in my 84 Suburban behind 6.2l Diesel.
    I mount a tps via custom made adapter at the IP in place of the original tpswitch.
    Now, I need an engine speed signal, too.
    The hole time I thought, it will be easy, because I wanted to use a trigger- or reluctorring from the 6.5l engine with original engine speed sensor und original front cover with ess-opening. Now, it seems that there is NO chance to get that reluctor ring somewhere.
    Is that right? Or did I overlooked something?
    Btw, is the 6.5 camshaft similar to the 6.2 camshaft in that area, where the reluctor ring and harmonic balancer sit?
    How did other guys get the ess from the 6.2l to use it for electronic shifted trannys?
    Greetings Marco
    If you want the reluctor for the CPK (crank position sensor), you'll need the 6.5 balancer. Otherwise, you'll need to use the oil pump drive ESS generator. Contact www.peninsulardiesel.com for that part.
    I personally would go with the Oil pump drive that has the ESS.
    Easy in out swap.
    Now if you need vacuum for the HVAC then you will need to retain the pump or convert to a serp drive up front that has a vacuum pump.
    There are trade off's either way.
    Oct 2002
    Statesville, NC
    Google search and download "The DB2 Conversion Guide" by Bobbie Martin and you will have all the info you need.
    97 Tahoe / 6.2 .030 Over, GM4 Turbo, Mechanical IP, Flow Cooler WP, K47 Air Box
    04 F-250 Cummins Powered
