Results 1 to 12 of 12
Thread: Turbo upgrade
    Columbia, TN ,USA
    Default Turbo upgrade
    The OEM turbo is finally showing some bushing wear after 18 years, two engines, 4 IPs and 168K miles. Wondering what is out there these days an improvement over the stock GM-8 unit. Not looking for huge numbers but 20 some odd years after the OE turbo was designed there has to be advancements in designs to benefit from.
    Truck is:
    -2000 K3500, 6.5TD/auto, CC, LB, SRW, 4x4, 4.10s, 265/75-16s
    -engine was replaced in '04 with a Navistar blocked long block and has ~70K on it now.
    -3" down pipe, 4" exhaust, remote FSD
    Would like to get a manual wastegate so I can ditch the vacuum pump(original). A replacement GM-8 center section would most likely be the cheapest/easiest but I'd like something better.
    The truck is used as a truck. Probably has a trailer hooked to it or a load in the box more times than not.
    Thanks, Dan
    2000 chevy crew cab 4x4 SRW 6.5TD/Auto/4.10s
    2014 Cruze Diesel
    Festus, MO.
    Center section is a fast and easy way...
    I bought a well used GM8 to replace my aging GM4 and added one of the rebuild kits you see on ebay for about $40. There isn't really much to them. If you can rebuild a lawn mower carb you can rebuild a turbo. Hardest part was getting the screws out of the housings which you'll have to do no matter. Just no room to get anything but an open end wrench on them. I ground several heads off and then extracted the remaining bolt after the fact.
    In hindsight I wish I would have spent a few extra $$ and replaced the compressor wheel as it does so some wear on the edges however it's still a nice improvement over the old GM4.
    Big Green
    '95 k2500
    Quote Originally Posted by Diesel Dan View Post
    I installed the Turbomaster manual wastegate and ditched my vacuum pump. I love how it keeps boost constant and consistent. Just be forewarned that the ECM may not like losing control of the boost. My ECM would constantly throw a CEL and put the engine into limp mode after the install. I had to install a chip in my '95 (your 2000 will need to have a flashed ECM). Took two tries with the programming to get it right, but now she'll pull all day long without an issue.
    Sep 2003
    Feeniks, Aridzona
    Look up Ronniejoe on here and talk to him about one of his turbos. He has a custom setup that just flat out works. I'm seriously considering selling off my TE06H and buying one of his.
    Arrow Holset HX35
    Going back several years, we've published stories about using the highly available Holset HX35 and 40 turbochargers on the 6.5L diesel. The common 35 is sourced from a 1994-98 Dodge Cummins (and other apps). It's wastegated and there is a Turbomaster available for it. The 35 works great on stock compression engines and the 40 works great on 18:1 engines.
    Going back 10 years now to 2008, here is a link to a story we published about using the Holset HX35 on the 6.5L diesel:
    http://www.thedieselpage.com/members...rysholsetc.htm
    I tried and tried - going back more than 10 years - to get some vendor somewhere to offer a turbocharger option that performed better than the stock GM series. My pushing, pleading and cajoling never resulted in a turbo kit being offered. We've waited too damn long, so I began the process of designing one in 2017. Later this summer, I'll offer a sweet looking bolt-on kit that makes swapping a Holset HX35 onto a 6.5 both easy and inexpensive.
    Cool! Looking forward to it!
    I finally located a super machinist/welder/fabricator who has access to everyone and everything state of the art. Helps that he likes diesels too.
    In the meantime, I found another TDP article I wrote some 6 years ago that explains more of the story. This one is a prelude to what's coming, and it's available right now to everyone. The kit parts will look quite a bit different than anything shown in these photos.
    http://www.thedieselpage.com/archive/2012turboc.htm
    Sep 2003
    Feeniks, Aridzona
    https://ptwiringsolutions.com/produc...i-downpipe-kit
    Dec 2009
    In the North
    Some folks are running a hybrid 35/40 unit
    With the 35 exhaust side and the bigger 40 airside, its in my plans, along with the 3"-4" system from diamond eye, along with a tune from quadstar,.
    I don't think i will put the 5068 pump on yet, this truck has pretty good power for a stocker,
    1999 chev suburban C2500
    300,000 mi
    Looks good! Solves a lot of problems if the kit works like it should. Bruce Kirkendall was a members in 2012.
    We'll see what develops, but I plan to keep going. What I had in mind is a bit different, more refined, when compared to what we published in March 2012.
    Always good to have options!
    Columbia, TN ,USA
    Yes it is!
    MP, thanks for the update and let us know how the kit turns out.
    For now I've picked up a rebuild kit for the turbo. Time is my enemy right now, in the process of building a new shop/house. Had crews do the foundation/block, concrete, rough frame and roof. I doing all the doors/windows, interior framing including the second floor(exterior was framed with 16' studs) plumbing, electrical, hvac, siding (35 sq) etc.
    2014 Cruze Diesel
