Check the radiator cap
Silver89,
My 2006 D/A used small amounts of coolant for about 50k miles. Jim came to the rescue when he wrote a DP service article on radiator caps. I checked my radiator cap and the spring was frozen and would not move. I took the blunt end of a screw driver and hit the inside of the cap to free up the spring and it solved the coolant issue. I quickly replaced the cap with a new GM cap and it hasn't used any coolant for the last 75k miles. A new cap is only about $15.00 and would be an easy fix if you are lucky.
Good luck
John
*2007 Pontiac Solstice.
