Originally Posted by
torque
I had the factory install adjustable axles on my first 5th wheel in order to raise it enough to get the 6" clearance above the truck bed rails. My second 5th has Moryde axles which are adjustable. You could also "flip" the axles under the springs too. In any case, you need 6" above the truck bed rails.
Is 6" enough?? With my 38' enclosed I had 6" of bed rail clearance but still dinged the bed in 3 places, 3 times. I have since raised the clearance to about 7.5"+ and no problems. Adjusted the gooseneck about 2" and switched from 15" to 16" wheels with heavier, larger diameter tires gaining 1.2" total @ the wheels.
Or is the problem more from tight turns on slopes and hills of southern Ohio and Ky. and Tn.?? bob.........
Bob O.
