Results 1 to 7 of 7
Thread: Need Help
    Apr 2012
    Arkansas
    Default Need Help
    I have a 2002 2500HD 6.6 Turbo. 268,000 miles. Well maintained. Injectors replaced at 85,000 under warranty. Pump changed 2 years ago. I have now gone from a bit over 15mpg to 13.47mpg. Idle is a bit rough and white smoke from exhause when idling. Could it be anything other than injectors and is there a way to determine which injector might be bad? Thanks for any help and I wish everyone a blessed Thanksgiving!
    Simple, blunt, and to the point: Injectors are the most likely cause.
    Apr 2012
    Arkansas
    That is what most everyone says.
    Dec 2002
    Teton Valley, Idaho
    On the bright side, almost 200K on a set of LB7 sprays ain't bad...
    Apr 2012
    Arkansas
    Default Really?
    This is the first Silverado I have ever owned. Prior to that was my 1974 Chevy 1/2 Ton which I still have! I was unaware injectors have to be replaced. Wish they were like spark plugs!
    Oct 2014
    Jackson, MI
    Recommended injector replacement is every 100 anyway. Get Bosch standard pressure injectors - they won't do you wrong.
    After almost 200k it's hard to argue that you need supporting items like lift pump and filters etc, but I still say ounce of prevention= pound of cure.
    Fresh stock injectors, fresh supply lines, and a pr of thermostats would be my minimum. All kept in stock here at competitive prices.
