TheDieselPage.com Forums
2017 - TDP's 21st Anniversary
Go Back   TheDieselPage.com Forums > The Diesel Page Member Forums > 6.2L Diesel
6.2L Diesel 1982-93 6.2L Diesel - Member access forum for any questions or information exchange related to the 6.2L engine.
Reply
Thread Tools Display Modes
  #111
Old 05-13-2017, 08:31 PM
Dvldog8793 Dvldog8793 is offline
Enthusiast
Howdy
A couple easy things to try....run a line bypassing the secondary filter directly to the primary. So your line will go from the LP to filter to IP.
How much soft line is in place before the LP?
Can you run your feed line to the LP from a separate source, like the boat tank or motorcycle tank? It this works it will get you to the yard.
I am wondering if you have allot of soft line before the LP if it is sucking it down enough to restrict fuel flow.
__________________
2001 Chinook RV, V10 gas
1967 GTO, 1989 Honda Transalp
3 kids, 1 wife, 1 dog
  #112
Old 05-14-2017, 01:48 PM
Bigshankhank Bigshankhank is offline
Enthusiast
Tried the boat tank to no avail, so I am dead in the water. Getting a tow in the morning.
  #113
Old 05-17-2017, 11:37 AM
Enthusiast
So the mechanic has confirmed that the IP is bad so he are working on a quote to remove & send to the injection shop in Clearwater (apparently they are THE injection pump shop in the area). He also mentioned that the new lift pump was not functioning. When I removed the old one, I used the grease on the actuator rod trick to hold it back in there when I installed the new one. Of course once its on, is there any way for me to confirm that it is in fact actuating the lift pump? Is there anything internally that a PO could have disabled, or that may have ceased to function causing the lift pump to not operate? As I understood it, there is a cam connected to the crankshaft which pushed the rod against the arm of the pump, and the spring under that arm returns the rod as the cam turns away.
  #114
Old 05-17-2017, 01:42 PM
Enthusiast
With the LP CONFIRMED not working. I wonder how they tested the IP?
In my experience those Mechanical LPs are pretty solid. If you got the rod in place, I would want to see it verified DOA. More likely that it is struggling to get fuel. This seems to be the common problem, fuel supply to the engine. Whether it is a tank pick-up problem, Lift pump or injector pump problem. Since you had the truck running at one time I would not be so quick to jump into an IP.
__________________
  #115
Old 05-17-2017, 06:05 PM
Enthusiast
As I'm understanding it, the mechanic noticed there was no fuel at the secondary filter so he bypassed the LP with an electric pump. Once he got fuel to the IP, the IP was not consistently delivering fuel to the injectors.
Reply
Tags
glowplugs, ignition, starting
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
Copyright 1996-2017 by TheDieselPage.com - All Rights Reserved
