TheDieselPage.com Forums
2017 - TDP's 21st Anniversary
Go Back   TheDieselPage.com Forums > The Diesel Page Member Forums > Photo Forum
Photo Forum Introduce yourself. Show us pics of your ride.
Reply
Thread Tools Display Modes
  #1
Old 10-11-2017, 05:50 PM
artfull dodger's Avatar
artfull dodger artfull dodger is offline
Newbie
Default Greetings from Indiana
Hello everybody, been away from the GM diesel world for awhile, but rejoined last fall and finaly got around to coming back here. Picked up a super clean '94 C2500 6.5td. Originaly owned by a profesional diesel mechanic, second owner needed to sell to settle a divorce issue. Super clean, 98% rust free, just starting to see some issues in the bottom of the drivers door. That will get fixed along with the silver paint on that door and the roof that is going south. The rest of the truck just shines! Only changes since the pics are I changed the axu lamps to KC amber fogs(lost one of the old ones to a rock, KC's have Lexan lenses) and I finally installed OEM style roof marker lamps. She is my dd to work and pulling my small trailer with my custom diesel powered Wheel Horse garden tractor to shows. Engine runs flawlessly, only thing I have done is the SSdiesel remote PMD cooler. Next upgrade is the fluid damper, I keep checking the damper when I change the oil, looks good so far. Truck has 149K on it, engine looks to be original and is a 599 casting. Keep forgetting to look to see if I can tell if the IP has been changed ever. Starts super easy so I am wondering if the pump has less than nearly 150K miles on it. Exhaust is 3" straight off the turbo, but looking at muffler options as its a bit obnoxious at 5:30am on the way to work. Interior is as nice as the outside of the truck, all the options work, and the air is ice cold. I do believe the PO is running her without a thermostat as the old girl never shows much on the temp gauge in the winter(I get heat though). Or the stat is in the failed open position. Will look into that before it gets any colder. Going to go thru my grounds this weekend as my new job will require her to sit in the lot for 10 hours, so if its -20 wind chill, I need her to start when I go home. All 8 glow plugs were replaced right before I bought it, along with two new batteries. Here is a pic of her taken earlier this year. Mike
__________________
Silly NT's....I have Asperger's!
1994 Chevy C2500 6.5td
SSDiesel Heatsync
4L80e built
150K miles and counting
  #2
Old 10-12-2017, 06:25 AM
arveetek's Avatar
arveetek arveetek is offline
Moderator-Towing Forum
Welcome back! Nice looking rig.
__________________
1995 K1500 Tahoe 2 door, 6.5LTD, NP241, 4L80E, 3.42's, 285/75R16 BFG K02's, Kennedy OPS harness, gauges, and TD-Max chip, Dtech FSD on FSD Cooler, vacuum pump deleted, Turbo Master, 3.5" Kennedy exhaust, F code intake, '97 air box, dual t/stats, Racor fuel filter, 320K miles and running strong!
  #3
Old 10-12-2017, 10:21 AM
DieselDavy DieselDavy is online now
Enthusiast
Greetings and welcome from Fort Wayne!
__________________
Dave, N9LOV
Member #242
Dave's Diesels:
'97 2 Dr Tahoe, Intercooled,
Kennedy ECM, 4" Exhaust
'02 GMC
  #4
Old 10-12-2017, 05:33 PM
Newbie
If anybody local has the Tech II scanner that can do the relearn so my IP knows it has a #9 resistor, I would be greatly appreciative. Thanks guys. She is my pride and joy! Mike
__________________
SSDiesel Heatsync
4L80e built
  #5
Old 11-27-2017, 08:01 AM
Robyn's Avatar
Robyn Robyn is offline
Missy Good Wench ( Moderator)
Actually the use of the number 9 resistor is a tad more complicated than just a relearn.
Each injection pump requires a resistor to get the ECM and the IP all calibrated
The resistor is a calibration tool.
To be able to use the #9 resistor you need change the chip in the ECM to one of the aftermarket programmed chips.
Then to really use the extra fuel and other changes to the ECM you need a good high flow exhaust and a spring type waste gate controller is a good choice as well.
The tech 2 tool can get TDC OFFSET done for you and other things too.
If you don't know what resistor was in the critter then usually a #5 will work without the computer complaining.
__________________
(1) 95 Suburban 2500 4x4
(1) 2017 Mercedes C class
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
