Thread: 91 6.2 "death wobble"
    Jul 2008
    Lansing ,MI
    Default 91 6.2 "death wobble"
    I have the occasional death wobble of the front end when coming to a stop. (Mostly happens when I have a trailer. Is it time for new tires? What causes this?
    1991 6.2 with 127000 miles
    1991 Chevrolet Silverado 3500, 6.2L. 125,000 miles -Sold
    2007 Chevrolet Silverado LBZ - R.I.P
    2001 Chevrolet Silverado LB7-- Sold
    2011 GMC Sierra, LML- 39,000 miles. All stock
    Dec 2000
    Hawaii/Arizona
    You just have to go through the list of possible causes.
    1.) Tires that are way out of balance or badly worn.
    2.) Check steering linkage, ball joints & control arm bushings.
    3.) Check the steering dampening shock absorber.
    4.) Check for a cracked frame or loose bolts where the steering gear box bolts on. Have someone turn the steering wheel while you look at the gear box from above.
    5.) Check for a frozen brake caliber or warped rotor.
    6.) Check for a bent or loose wheel.
    Good luck
    John
    *2007 Pontiac Solstice.
    Good list, but add:
    Separated tire cord. This is common on old, but not necessarily worn out, in appearance. Jack the wheel off the ground and give it a spin. If the tread walks back and forth, or it's out of round, it's a possibility. Any obvious bulges are suspect.
    Wheel bearing(s). Check while the wheel is off the ground.
    Jul 2008
    Lansing ,MI
    I think I found the culprit. Bad outer tie rod end. I jacked the truck up and was able to move the tire about an inch side to side. I'm going to replace the inner/outer tie rod and adjusting sleeve.
