TheDieselPage.com Forums
2018 - TDP's 22nd Anniversary
Go Back   TheDieselPage.com Forums > The Diesel Page Member Forums > 6.5L Turbo Diesel
6.5L Turbo Diesel 1992-00 6.5TD - Discussion forum for the 6.5L engine.
Reply
Thread Tools Display Modes
  #1
Old 04-15-2018, 06:03 PM
jggiedeman jggiedeman is offline
Enthusiast
Default Date code stamped in block near PMD
I have a 506 block, 1255506, E148. Figured it to be made May 14th, 1998. The code I'm referring to is actually not stamped but appears to be etched in in the block. Up front on left head bank next to the Inj Pump PMD. Reads YDD 05 27 J8. I figure the 05 27 refers to May 27th.
So what is the YDD and J8?
Thanks
__________________
1994 K2500 ext cab. Recently repowered with; Non-cracked 599 block, factory compression, used old DSG girdle for main caps. Factory for what remains. Changed diffs to 3.42. Fuel economy Hwy 22.5 mpg US, in town without lcokup in 2nd/3rd - 18 mpg US.
1994 K3500 CC LB Silverado. Next project. Built for endurance, power and gearing. Plan on opened up intake and exhaust sytem, best cooling mods, 4.11 gearing 4L80E, followed by Gear Vendors OD. Need to be able to split all gears and have lockup in 2nd/3rd/4th. Tan interior cloth, Bad ass dark blue (coming) aluminum wheels and air ride (coming)
  #2
Old 04-15-2018, 07:47 PM
DmaxMaverick's Avatar
Administrator
Assembly line info (date, shift, crew, etc.). The date may be correct (2 weeks after casting isn't unreasonable), but you'll need an original Dick Tracy decoder ring to make sense out of the rest. I've heard several explanations, but none of them the same, and they are not consistent from plant to plant. Your guess is probably as good as theirs, unless someone chimes in who actually worked at that plant, at that time.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
