Results 1 to 2 of 2
Thread: '82 Airstream motorhome with 454 Chevy
    Default '82 Airstream motorhome with 454 Chevy
    I'm planing to buy an Airstream motor home and replace the installed 454 Chevy for a diesel. A few where made at the factory equipped with turbo diesel Isuzus but they are very underpowered. Does anybody now of any other engines suitable for such a conversion? Thanks.
    May 2007
    Dixon, CA
    If you look at the thread I have going "Converting and early motor home to diesel" you will see that I will be replacing my 440 with a Duramax Allison combination. You will need to do something to get your engine rpm down to the proper range for the engine you end up using. One of the aspects of the Duramax I like is the wider usable torque range of it vs other diesels.
    Good luck and I think we will both like our repowered motor homes.
    Stephen H.
    BigRabbitMan
    1976 FMC Motor Coach #1046
    Formerly 440, now LBZ
    Rear engined w/4 wheel independent suspension.
    Tow car: 1987 Subaru Brat 4x4
    http://www.fmcowners.com/mbbs22/phot...asp?albumid=77
