TheDieselPage.com Forums
2018 - TDP's 22nd Anniversary
Go Back   TheDieselPage.com Forums > The Diesel Page Member Forums > 1982-2000 C/K Truck & SUV Chassis & Drivetrain
Reply
Thread Tools Display Modes
  #1
Old 03-16-2018, 02:57 PM
94chev4x4 94chev4x4 is offline
Newbie
Exclamation NV4500 swap
New here, i have a 94 k1500 6.5 with an auto trans. Not an auto kind of guy!! I'm getting a parts truck, a 2wd 3500 manual. My question is, can i just steal parts from it and swap in the nv4500? Is the 2wd trans the same as a 4x4? And can i use the ecm from the parts truck in mine so it doesn't go into limp mode when it doesn't sense the auto trans? Or what will i need? Thanks for any replies
__________________
94 GMC 6.5td auto- stock for now
Dad's 94 GMC 6.5td auto- 4" exhaust and manual wastegate
2-96 Chev 6.5td- parts
Chev 3500 2wd nv4500-parts (unknown year)
  #2
Old 03-16-2018, 03:22 PM
trbankii's Avatar
trbankii trbankii is offline
Enthusiast
I’ve been considering a similar swap for my ’94 Yukon.
The 2WD and 4WD trans have differences. At a minimum, you have to tear the transmission down and swap out the rear housing and the mainshaft. Here are links to the pieces (LINK and LINK). Once you get into the trans, you’re likely going to want to replace bearings and seals since you’re there anyway.
The ECMs will also be different between the 1500 (L56) and 3500 (L65) engines. Kennedy Diesel (in the vendor section) can likely retune your 1500 EMC for the manual transmission.
__________________
94 GMC 6.5TD K1500 4L80E 2-Door Yukon SLE 216K
93 Chevrolet 6.5TD K2500HD NV4500 Std. Cab Longbed 184K
85 Toyota 22R RN60 4x4 Std. Cab Shortbed 178K (Currently retired for rebuild)
  #3
Old 03-17-2018, 04:53 PM
sctrailrider's Avatar
sctrailrider sctrailrider is offline
Diesel junkie
The auto truck will NOT have the mount up under the dash to mount the petal assembly fully, you will need to cut the spot welds and install it in the auto truck, complete removal of the dash will be needed. I will post a pic of the bracket if I can...
__________________
1993 Chevy K3500
like us on Facebook
  #4
Old 04-20-2018, 09:40 AM
JeepSJ JeepSJ is offline
Jeep Freak
If that 2wd NV4500 doesn't work out for you, I'd be interested.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
