Thread: Another K5 question
    Feb 2003
    Grand Rapids MN 55744
    Default Another K5 question
    The older Chevy trucks(1972-1990???) had a small metal reinforcement plate in the front inner fender. It has three bolts in it that tie the outer fender to the inner and who knowswhat else. Anyways...if you have ever owned one of these trucks you know that the plate was not sealed properly to the fender and moisture/RUST would build up behind the plate and eat it's way into the inner fender...by the time the plate itself showed some rust it was a inner fender hole about 4inches large. My question after all this rambling is.....Does anyone know where I can get these plates new? Or what the real term is for them...
    I am replaceing mine and sealing them before they get gone...
    Thanks!
    2001 Chinook RV, V10 gas
    1967 GTO, 1989 Honda Transalp
    3 kids, 1 wife, 1 dog
    Dec 2006
    North Pole, Alaska
    You should be able to get those from www.lmctruck.com
    Feb 2003
    Thanks...but no luck with out a name for the part as they do not seem to show up on a standerd body part blow-up.
    Any other ideas...?
    Take a good piccy and post it here, I will do some snooping.
    Now, the K5 went through several changes from 72-91
    The 72 was a totally different body
    73-80 were pretty much the same
    IIRC the 81-91 had basically the same sheet metal
    Get us a piccy of the part.
    Missy
    Feb 2003
    brace or bracket from inner fender of 1984 blazer, arrows indicate bolts, line is the outline of the brace. the picture is taken from on top of the tire looking back on the passenger side. Edge of the fender can be seen on the left side of the picture.
