Results 1 to 16 of 16
Thread: K2500 Right Motor Mount - $600?!
    Aug 2014
    MD, USA
    Default K2500 Right Motor Mount - $600?!
    hello everybody. Rather than trying to do the motor mount myself, I got an estimate for replacing the passenger side engine mount on my 6.5 turbo diesel K2500 Suburban. They quote $600 plus in labor alone.
    Seems like I might be doing it myself, but is it really a six hour job by a professional? I can't imagine how long it will take an amateur hack like myself!
    Any help/thoughts greatly appreciated.
    Ouch! Considering that the mounts themselves are about $10 apiece, that's a lot of labor!
    Replacing mine is on my list of things to do. I haven't tackled them on a 6.5, but from doing others I cannot imagine that there is nearly a full day's worth of work to do them.
    And I'd really do both of them at the same time. By the time you've gone to the trouble, you might as well do both - and I can't imagine that the driver's side is in any better shape.
    In 6 hours, the entire engine can be removed and replaced. Engine mounts should be less than one hour in a typically equipped shop (both sides, including the required union break). There's nothing special or complicated with the 6.5L mounts. Same as just about every other V8 powered light truck on the planet. That estimate seems extreme, even for a dealership.
    Jun 2013
    Northern Ct
    Go for the "2nd opinion". Get another quote, somewhere else.
    Old habits, die hard.
    Quote Originally Posted by joeq View Post
    This. At least.
    The other year, my neighbor was having t-case issues with his Suburban. Dealer wanted some ungodly amount - $5000 sticks in my mind - to replace the whole t-case. I asked why not just rebuild the t-case? Neighbor took it to a local shop and the guy said "Well, it is going to be costly - maybe $500 to $700 to tear it all apart and go over it..."
    Needless to say, my neighbor got it rebuilt and has been happy with it ever since.
    Aug 2014
    MD, USA
    Default 2nd opinion - $780 for both !
    Thanks for the input guys! Unfortunately, the 2nd opinion was $780 for both mounts! These are both independent shops, one I have used for years, so I don't think there's some sort of scam going on . . .
    That's pretty crazy. As I say, I haven't specifically done a 6.5, but it is basically just unbolting the mount, jacking the engine enough to slide it out, putting the new one in, lowering it, and tightening the bolt.
    Sep 2014
    NY
    Quote Originally Posted by George301 View Post
    George,
    FWIW at $780.00 I would/will change the engine mounts myself.
    Regards
    Joseph
    Hi
    Fairly simple job in a pain in the a$$ spot.
    Do it yourself over a weekend,and it will be like paying yourself $600-$700 dollars to learn how to work on your truck.I did the ones on my 98 K3500 and it was a pain,but simple.I went with polyurethane replacements.Mine were so bad in that in reverse the motor would lift about 1 1/2" when you torqued on it.
    Thomas
    Sep 2014
    NY
    George,
    FWIW....... just looked up a pair of new mounts for my truck, a 1986 K30 in polyurethane less than $31.00 each.
    It can not take 8 hour to chance the mounts.
    And you pay yourself $700.00
    Regards
    Joseph
    Jun 2013
    Northern Ct
    Are you sure the mount is even bad?
    Aug 2014
    MD, USA
    Well, I'm trying to get it thru Maryland inspection, and that's what the inspector tells me.
    My real problem at the moment is I have done so much other work, new injector pump, new heads, new bunch of stuff on the front end, new bumper, injectors, glow plugs, I just want the thing done ! Figured it would cost a reasonable amount and I wouldn't have to worry about it. Oh well.
    Jan 2005
    Denville,New Jersey
    The inspection station failed it because it needs a motor mount? I thought New Jersey had all the so called inspectors that let there authority go to there heads!
    Aug 2014
    MD, USA
    In Maryland you only are inspected once, when you first register a car, rather than annually, and it covers everything. I also needed to replace the bumper (rusted thru in a spot) several front end components, brake parts, door hinge pins (wouldn't latch smoothly) and more. At least I know its safe, (for the moment)!
    thanks for all the help on this forum
    george
    Sep 2006
    Brooker, FL
    I bought the mounts for my motorhome from NAPA, the local shop replaced both for ~$75; since my coach is a diesel pusher, the mounts are easily accessible...but I can't fathom $700 for the job on your truck.
    Feb 2003
    Grand Rapids MN 55744
    I had the pan removed/re-installed, both mounts removed/replaced and the oil lines replaced for $600. That was at a shop that had me at their mercy and did not know me....
    Good luck!
    2001 Chinook RV, V10 gas
    1967 GTO, 1989 Honda Transalp
    3 kids, 1 wife, 1 dog
