TheDieselPage.com Forums
2017 - TDP's 21st Anniversary
Go Back   TheDieselPage.com Forums > The Diesel Page Member Forums > 6.5L Turbo Diesel
6.5L Turbo Diesel 1992-00 6.5TD - Discussion forum for the 6.5L engine.
Reply
Thread Tools Display Modes
  #1
Old 12-05-2017, 12:59 PM
Arentfrow123@gmail.com Arentfrow123@gmail.com is offline
Newbie
Exclamation 6.5 Turbo Diesel p0236
Hey erybody, I'm new here, but have a quick question for ya. I have a 98' k1500 6.5. Runs great, but the code p0236 intermittently pops up, and takes my turbo with it. My turbo works about 25% of the time. I replaced the MAF sensor, the air filter, had a mechanic check all vacuum lines and pump itself. I've replaced a few other things that I've forgotten, but long story long. I've narrowed my problem down to either a failed boost or wastegate solenoid, OR!!! my terribly loud exhaust manifold leak. Someone help please, I'm running out of both time, and money.... and patience. Thanks kin.
  #2
Old 12-05-2017, 01:26 PM
Robyn's Avatar
Robyn Robyn is online now
Missy Good Wench ( Moderator)
HI
Check your vacuum pump and make sure you have at least 26" of vacuum at the pump.
Vacuum test gauge needs to be steady... If the gauge wobbles all over the pump is junk.
Be sure the vacuum is steady at the solenoid as well.
With engine idling there should be about 22" of vacuum at the waste gate actuator.
If the actuator has good vacuum, be sure the gate moves freely with the engine off.
Poor or no vacuum at the waste gate is an indicator of a failed solenoid
The solenoids were problematic on these at times.
Fix the exhaust leak.
__________________
(1) 95 Suburban 2500 4x4
(1) 2017 Mercedes C class
  #3
Old 12-05-2017, 02:04 PM
Newbie
Thumbs up
Okay, my mechanic told my that my pressure from pump was steadily around 20"... I'll try the solenoid seeing as I've already ordered it, but will re-check all vac lines including pump. Thanks boss.
  #4
Old 12-05-2017, 03:22 PM
Robyn's Avatar
At the pump (connected directly) you should see 26"
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
Copyright 1996-2017 by TheDieselPage.com - All Rights Reserved
