Thread: Hmmwv
    Feb 2016
    Default Hmmwv
    I recently purchased this 1987 HMMWV with a 6.2 L Detroit Diesel. I know two things about Diesel engines, Jack and Squat. So any help will be greatly appreciated.
    Hi
    When i got my signature truck i knew little about GM diesels.I was steered to this place.I did a bunch of reading because the motor had been run without coolant.I did the repairs myself after spending weeks reading on here.10 years and 50k miles the truck is running great and i would drive it anywhere.
    The 6.2 is a simple design and parts for it are cheap.With a military injection pump you can use pretty much anything oil based for fuel in a pinch,except straight gas.
    I will have a 6.2/6.5 till they take my license away.I have scrounged enough replacement parts to last that long as well.
    Wish i had a Hmmwv.
    And buy the diesel page books to keep with your truck until you have learned all about it
    Thomas
    Welcome to TDP
    I took the liberty of taking your piccy and turning it 90 degrees and adding it to your original post.
    Glad to have ya aboard
    Robyn
    Feb 2016
    Default Thanks
    Thanks for the advice. I have been reading a lot. I plan on buying the book soon too. I have recently changed out the glowplugs with an extractor because they were all swollen. I replaced an injector port too. I purchased some new optima red top batteries as well. I'm learning. Slowly but surely.
    Feb 2003
    Grand Rapids MN 55744
    Howdy
    When it comes time....I have some experience working with HMMWV. I f you need anything or have questions about the specifics of HMMWV drive train or construction let me know.
    Good luck! Your rig is my DREAM machine!
    2001 Chinook RV, V10 gas
    1967 GTO, 1989 Honda Transalp
    3 kids, 1 wife, 1 dog
