Results 1 to 8 of 8
Thread: Lots of black smoke and no power 6.5 diesel
    May 2017
    Seattle Washington
    Default Lots of black smoke and no power 6.5 diesel
    I have a 1995 gmc 1500 So I noticed my truck has been putting out a lot of back smoke when you get on it and feels like it has no boost or power.
    List of parts I have replaced and cleaned
    Map sensor
    Turbo boost sensor
    Vaccum pump
    New Pdm and relocation kit
    Turbo boost selnoid
    New fuel filter
    The truck has stalled on me before and takes alittle bit to start back up but will start
    Also when I'm starting from a stop the truck will kinda jerk alittle bit then after the jerk it will drive just fine
    Quote Originally Posted by Ryanr8 View Post
    Map sensor
    Turbo boost sensor
    Vaccum pump
    Turbo boost selnoid
    New fuel filter
    A boost gauge is key to diagnosing these issues. That or a vacuum gauge to test the wastegate control system.
    May 2017
    Seattle Washington
    Where can I tap in to install a boost Guage i have one laying around the house right now
    Feb 2003
    Grand Rapids MN 55744
    Howdy
    I tapped into the air horn on top of the manifold. This is the top of the manifold that connects to the turbo.
    This can be done pretty easy. loosen the silicon coupling to the turbo, 6 bolts to remove the horn, pick a spot along the edge that has thick material, drill and tap a 1/8 pipe thread. Make sure you don't get metal in the manifold. On most air horns there is a small flat area on the back passenger edge(?) that is a great spot for this, but any place on the air horn or manifold will work.
    Good luck!
    2001 Chinook RV, V10 gas
    1967 GTO, 1989 Honda Transalp
    3 kids, 1 wife, 1 dog
    May 2017
    Seattle Washington
    The upper manifold all that's on there is my egr and map sensor and iat sensor
    Feb 2003
    Right, upper manifold. My wording is different. Any place in the upper is fine. The thicker the better.
    May 2017
    North Carolina
    Default Turbo Boost Bolt
    Go to Leroydiesel.com and buy the turbo boost both and replace one the the 2 center bolts on the plenum and then attach the boost gauge to that. Turbo boost bolt is 30 bucks and no drilling and tapping required.
    1995 Chevy 2500, 6.5L Diesel mostly stock 234,000 miles. Changed the water pump to HO WP, deleted the vacuum pump and added a mechanical wastegate controller made by me with info from others on the forum.
    Dril and tap the round part of the upper intake plenum with the port facing rearward. Less strain and good solid mounting point.
    Shown in one of my pics here:
    http://www.kennedydiesel.com/airboxmods.cfm
