Thread: Blue smoke
    Dec 2014
    Kellogg, ID
    Default Blue smoke
    94 6.5 turbo diesel blows lots of blue smoke out the tail pipe..... Sometimes.
    Carl in Idaho
    Smile this is as good as it gets
    Sometimes? What times?
    Dec 2014
    Kellogg, ID
    Had my cousin follow me and huge cloud of blue smoke out the exhaust then it stops then it starts. Seems random
    Carl in Idaho
    Bad injectors would be a place to start.
    Worn out squirts will cause myriad issues.
    Does the engine misfire (run rough) ????
    If the thing runs reasonably smooth then I would yank the injectors and have them checked by a good injector shop.
    Check pop pressure and spray pattern.
    Low pop pressure and a pee stream instead of a nice cone of mist will cause a smokey mess out the tail pipe.
    Any check engine light (SES) ????
    If the light is on/has been on pull the codes.
    Good luck and let us know what you find.
