Results 1 to 2 of 2
Thread: 6.2 flywheel
    Mar 2017
    usa mich burton
    Default 6.2 flywheel
    Hello to all will a flywheel from a 1996 6.5 td fit a 1984 6.2 I can get bellhousing flywheel for 200.00
    Hi
    I don't think it will.
    The 6.2 in 84 had a two piece rear seal,and the 6.5 has a one piece rear seal.The end of the crank was changed to accommodate the one piece seal.That change makes the flywheels different for the 1 or 2 piece seal.
