Results 1 to 9 of 9
Thread: 01 to 05 brake controler install
    May 2002
    ma
    the 01 is on the way out and the 05 should be here this week
    i remover the brake controller from the 01.
    can i just plug it in to the 05 or do i need to rewire it to a new plug.
    tia.
    jim
    jim
    Mobile, AL U.S.A.
    You will have a new plug.
    2005 Chevy 2500 HD Duramax CC SB 30,000 miles.
    1994 GMC 2500 Suburban 6.5 TD 210,000 miles.
    1983 Mercedes 300 D Turbo Diesel 150,000 miles.
    1991 Holiday Rambler Aluma Lite XL 30 foot.
    May 2002
    ma
    i kinda figured that.
    i want to know if it's the same so i don't have to rewire the controller.
    jim
    96ccdd Guest
    My understanding is you will have to rewire it because the pin location in the fuse box is different.
    May 2002
    ma
    thanks
    jim
    Nov 2004
    Blackie
    When i changed from 02 to 03 i took harness and control and transfered to 03. It plugged in OK but big mistake. Pins are different. Check with your hitch people or dealer if you want to lower your pride enough!!!
    Dec 2004
    RVing the USA
    There is an upfitter bulleting at the GM website that explains what changes to make to your old harness. If you don't make the change, your brakes will apply when you turn on your lights.
    DOOH!
    I think the new harness is $25
    May 2002
    ma
    two of the wires are different on the 01 plug
    i didn't rewire the controller, i just pulled the pins and swapped the two wires. as i recall they were the light blue and the brown.
    on another note my banks exhaust from the 01 bolted right up to the 05 as did my front mounted hidden hitch.
    jim
    Dec 2004
    Western Michigan
    That's all I did going from my '02 to my '05. The '05 came with the proper plug in the glove box. I'm almost sure the '02 did too.
