Originally Posted by
justlkn
Emissions equipment is required by Federal law to be covered for five years or 50,000 miles.
And no mods to the motor. I did debadge some here and added some chrome there but keeping her stock for as long as possible. I bought her to work and that she does that well.
Or until the District Manager decides that he does not want to warranty your truck anymore and decides to pull the plug on your extended warranty on unfounded reasons after almost 2 years of documented problems with the vehicle with no solution. GM does not have a solution to the problem and does not know how to correct the problem.
2012 LML SRW 3500HD LTZ long box
Mods: Spray in Line-X bed liner, 20K QCurt, tinted windows, Futomo oil drain valve, (pulled stock intake out and installed Airaid cold air intake after regenerations were taking place every 200 miles to try and salvage MPG), Edge Insight monitor.
Pulling a Dutchman 3530FBH fifth wheel. Weight empty 12,500lbs. probably been up to 14,000lbs.
