Results 1 to 9 of 9
Thread: Synthetic Oil
    Nov 2005
    Red Deer Alberta Canada
    Angry Synthetic Oil
    Not bring familiar with synthetic oils,am wondering
    if this is a normal colour of oil after about 8000 miles.
    Mine was the colour of the icon above.
    Don
    Sep 2006
    Brooker, FL
    Motor oil? It should generally be dark grey or black, caused by its doing the job of getting contaminates into suspension.
    ATF should be red or pink.
    Nov 2005
    This was motor oil,engine has 90K miles.
    2005 Impala.
    Jun 2000
    Morrisville, VT, USA
    Don: Is your coolant going down, and your oil level rising? Just a thought.
    Nov 2005
    No the coolant is fine.
    Had the oil changed 3 days ago,they checked
    the coolant levels and said it was fine.
    Am surprised that in 8000 miles the oil
    was only down about 3/4 of a letre.
    Milage is good at 38 mpg(imperial)highway.
    Check mileage every tank(calculated).
    New oil is Pennzoil Platinum 5W-30.
    Will watch it closely in the future for
    any colour change.
    Sep 2006
    Brooker, FL
    I thought you were referring to a diesel. Gaso engine motor oil will change color very little. The pink color doesn't signify a coolant leak - that would cause cloudiness and a mayonnaise-like sludge.
    With few exceptions, the only thing you can tell from the color is...the color.
    Nov 2005
    Thanks Rustyk,when you reach
    82 you have tendence to panic
    over some thing new.
    Will put head in the clouds and
    forget it.
    Quote Originally Posted by rustyk View Post
    I'd further say without knowing what the original color was, that's about all you're going to be able to say.
    Nov 2005
    I live in Canada.
    Bought the car from Son-in-Law.
    Phoned chev dealer in Blaine WA
    who did all the servicing on this car.
    Was told it was mobile 1 and they
    said the colour was normal.
    Panic button OFF!
