TheDieselPage.com Forums
2018 - TDP's 22nd Anniversary
Go Back   TheDieselPage.com Forums > The Diesel Page Member Forums > 6.2L Diesel
6.2L Diesel 1982-93 6.2L Diesel - Member access forum for any questions or information exchange related to the 6.2L engine.
Reply
Thread Tools Display Modes
  #1
Old 11-20-2017, 05:05 PM
Jakeelliott Jakeelliott is offline
Newbie
Default 1985 6.2L Diesel stalling problem while running
So I have a 1985 6.2l diesel Silverado k10. And Iíve been having this issue for a while now to where it gets into the 3rd gear before overdrive in my transmission which is a 700r4, the truck will be running and get close to around 45mph or maybe even slower then the truck will just die. I donít know if it is a vacuum problem with the transmission or engine or a fuel pressure problem. I would be grateful if anyone had any information on how to possibly fix this issue!
  #2
Old 11-21-2017, 09:15 AM
Robyn's Avatar
Robyn Robyn is offline
Missy Good Wench ( Moderator)
Hello
Welcome to TDP
Fuel starvation likely
When was filter last changed ????
Check lift pump for delivery
Unhook pink or red wire (large) on injection pump.
Unhook fuel line that feeds the filter from the fuel pump on the engine and direct it into a can.
Get helper to crank engine ad watch fuel delivery.
No fuel...bad pump
Good fuel delivery ...changed filter
After filter change
Keep wire off IP and open air bleeder on filter and crank until air free fuel comes out.
Close bleeder
Hook up wire on IP
Start as normal
Engine may run rough or surge a bit until any air purges.
Good to go..
__________________
(1) 95 Suburban 2500 4x4
(1) 2017 Mercedes C class
(1) 1997 Astro "CATVAN II"
  #3
Old 11-23-2017, 11:24 AM
Newbie
I have already replaced both the filter and the lift pump and have the same issue
  #4
Old 11-24-2017, 06:56 AM
Robyn's Avatar
Get a piece of clear plastic tubing in the fuel return line and route it up by the wipers (Temp for testing) and run the beast.
Watch for signs to air bubble streams coming through.
If you are getting air then either your main line between the tank and the lift pump has a hole or the in tank equipment (Sock and such) has issues.
Get a low pressure gauge between the filters and the injection pump and route it so you can see it, run the rig and see wasssssup.
When the truck dies, will it restart easily, or does it require much cranking ?????????
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
