Results 1 to 20 of 26
Thread: What tires do people buy?
    May 2012
    Langley
    Default What tires do people buy?
    I've got Hercules 265's All Trac A/T right now, they came with the truck and their fine at the moment.. But they are definitely getting old... I probably have 1, maybe 2 years left on them.
    I was going to replace them with more or less stock 245's but then I bought a 5th wheel and I now need the extra weight capacity.
    What do people buy, where do they buy em?
    I live in Canada, but I can have things delivered to my US mailbox.
    Thanks in advance
    Dec 2000
    Hawaii/Arizona
    Michelin or Cooper would be a good starting place to look for quality tires. I actually liked my Cooper ATR tires better than the Michelin and they were much cheaper. The Michelin tires rode better but the side wall seemed to flex in turns. I just didn't like the feel of the Michelin tires on a winding road.
    Be very careful with the Hercules MIC (made in China) tires that you are currently running. When I converted my Dually from 16" to 19.5" tires I took a chance on the less expensive Hercules tires. That was a big mistake. The left front tire blew out and did $4,600 damage to the left side of my truck. The tire was in great shape and gave no warning that it was about to fail. Hercules would not do anything because there was nothing left but the bead ring. I also had three MIC (Marathon brand) tires that separated belts on my 5th wheel. The bottom line is don't buy made in China tires. Additionally, check the date code on the tires and insist on tires less than a year old.
    Good Luck
    John
    *2007 Pontiac Solstice.
    Hi Gary
    If it were my truck i would go with LT235/85-16.
    Seeing where you live i would be heading to Washington to buy them,or pick some up on your travels in the States,tires are way cheaper there.
    If you plane on mostly highway i'd get a Michelin LTX,if you plan on of road Michelin makes a tire with steel sidewalls and has a rib for summer,or a more open for all season,cant think of the modle but can find it if you need.
    Toyo makes a good tire,bridgestone as well,Goodyear as well.The Michelin's with the steel sidewall i get recaped for my duallys.
    Did you end up with 15's on your trailer?I have seen some Goodyear LT235/75-15 that have a load range D rating,and made in the States.
    Good Luck
    Thomas
    May 2012
    Langley
    Thanks for the replies, I'll try to price them out next time I'm stateside.
    I was originally thinking of staying with 265's given that my truck with the camper is technically overweight, but even with that it's still withing hte load range for the real axle so I guess it kind of doesn't matter.
    Thanks for the info on the Hercules tires, that's food for thought too.
    Edit, adding response regarding trailer tires.
    Their 15's, I haven't had a chance to do anything with them yet. Probably do that next month when I have a chance to get stateside.
    Last edited by gary_lucas; 05-29-2013 at 21:11. Reason: added response to trailer tires
    Sep 2006
    Brooker, FL
    I just replaced the Dayton 235/85R16s on my 1T LWB Ford diesel van with Firestone Transforce HT of the same size. Can't tell any difference in ride or handling. Both are all-season designs.
    I can't complain about the Daytons (also owned by Bridgestone) - they lasted 10 years in FL. With around 70K miles, the Daytons still had ~40% of tread left, and that on the biggest van Ford made in '87.
    Dec 2006
    North Pole, Alaska
    I run Bridgestone Duravis M700HD's in 235/85R16. Not the cheapest tires, but they wear nicely and do well all season up here in Alaska. I may sipe them just for a little better traction on ice, but it wasn't bad.
    I loved my BFG A/T's when I ran them on my K2500 Suburban. They were good tires, a bit on the heavy side and noisier than some of their competition. However they never let me down and got me through mud/sand/snow/highway/anythingitriedtodrivethrough without issue.
    Quote Originally Posted by CoyleJR View Post
    ...The bottom line is don't buy made in China tires. Additionally, check the date code on the tires and insist on tires less than a year old.
    Good advice....
    Jun 2005
    St. Augustine, FL
    Default Michelin
    I replaced the factory Bridgestone 245/16's with 265 Bridgestone Revos. They were okay to start with, but as they wore down (30K) they started to get noisy. I replaced them with Michelin 265 LTX MS2's and never looked back. A bit pricey, but a great tire. I should get 60K from them easily. Great on wet pavement, no snow in Florida (yet) and a good trailer towing tire.
    2005 Chevy 2500HD, CC, SB, 4X4, Duramax, ARE Topper, 60 gallon RDS toolbox/tank combo, Kennedy Headlight Booster, Isspro pyrometer and boost gauges, EGR Blocker, PCV Kit, Bilsteins, 265 Michelin MS-2, TTS Exhaust, pulling 35' Jayco travel trailer.
    Maplesville, AL - Home Base
    x2 on the Michelin LTX MS2.
    Ed
    KM4STL
    Oct 2000
    Peterborough, ON. Canada
    Well, I have used GoodYear 245 Wranglers ever since I wore out the factory tires. I get about 110,000 km's a set and I like the kevlar side walls. I have never had a flat or even a slow leak. I run them at about 70 psi and they ride just great.
    2001 GMC 2500HD Ext cab SB Dmax 6 speed
    86 6.2D
    79 5.7D
    D.P. member # 1885
    Ontario Plate "DMAX DSL"
    Jul 2012
    North Texas
    BF Goodwrich. I get 80K on Rugged Trail 265/75/16 Great wet/dry traction and good light off road traction. Also if you want a more aggressive tread go with the Rugged Trerrian very good offroad with no on-road sacrifice.
    2003 CC LB Duramax Victory Red
    70 CST/10 Short/wide (Barn Find) project 5.3L
    64 Short Stepper
    1997 Grand Prix GT 285,000 all original and going strong
    1987 IROC-Z Yellow T-top swapped LT-1
    2008 Impala LT
    1999 Z/71
    20ft CrownLine bow rider 4.3LX Mercruiser (soon LT1)
    30ft travel trailer
    I want a Factory-Five Roadster (Cobra)
    Just bought a set of Cooper Discoverer A/T3 tires in 265/75R16 size. $835.80 out the door from a local Tire Rama tire store, which included mounting, balancing and new metal stems.
    http://www.cooperdiscoverer.com/
    http://www.tirerama.com/
    These replaced a set of Michelin LTX that had nearly 60K on them. The Discoverers are pretty aggressive looking, but are quiet - so far, and should work well during our Montana winters. The truck's handling appears to be pretty good too.
    Thumbs up
    Got a couple hundred miles on the Cooper Discoverer A/T3 265/75R16 tires now. They are quiet, and the balance job performed at the local Tire Rama is excellent. I noticed that the tires required very little in the way of balance weights. This tells me that tire quality is pretty good. Jim
    May 2012
    Langley
    Awesome information, tires are important. I'm likely going to spend some time next year pricing out replacements for the hercules next year.
    Probably do it on vacation heading south next year and get the benefit of cheaper US prices.
    Jan 2006
    South Milwaukee, WI
    Thumbs up New tires
    For my money, I'm on my third set of BF Goodrich Commercial T/A Tractions. Yes, they are a very aggressive tire for over the road use, but they wear great! I put a good 600 miles on my '01 Silverado weekly traveling between WI and IN for work. I replaced the last set at 108K miles. 2 tires were practically down to the wear bars (Colorado mountains and a trailer were murder on the new tires) and the other 2 still had a few thousand left on them.
    The set before that went a good 95K miles and I replaced them before the snow started flying (wanted the assurance of decent traction before hunting season). I've run the T/A Tractions from BFG and they were OK too- but expensive and they didn't last like I'd prefer. I like the commercial version. Mine are 245-74R16Es. You'd probably like them too.
    "Chessy56"
    So. Milwaukee, WI
    '01 2500HD, LB7, ~440K miles
    Winston Churchill
    Apr 2009
    Western KY
    I like General Grabber AT2s
    May 2012
    Langley
    So, tires shot... Had a shimmy in the back end for awhile... Asked mechanic, he put the hercules on the machine and they were obviously done.
    Going to get a set of coopers, staying with 265 due to load limit concerns (5400lbs right now).
    Will pick them up once I get over this stupid stomach flu.
    G
    Gary, I've had the Coopers now for a little more than a year, which included a snowy Montana winter. So far so good. Work well in the snow. They're quiet at highway speed, but you can hear them at lower speeds with the windows down - not objectionable at all.
    May 2012
    Langley
    Good to hear, thanks for the info.
    Just got my tires (feeling ok right now).
    Shimmy is completely gone, tires look good.
    Tire guy said the tread had separated and I was lucky I hadn't had a blowout.
    He also said I shouldn't have been using the hercules for towing.
    G
    Jan 2006
    South Milwaukee, WI
    Wink Tires.....
    I've grown accustomed to the BF Goodrich Commercial TA Traction tires. Mine are "stock" @ 245/75R16E. I get around 90-110K on them, which is mostly highway miles. The last set probably would've gone a bit longer, but I prefer traction in the Wisconsin winter months. They've lasted longer than the others I've tried, although they do have some inherent road noise being they are "aggressive". I'm on my 3rd set now and would buy another. They are meant for commercial applications.
    "Chessy56"
    So. Milwaukee, WI
    Winston Churchill
