Page 1 of 3 123 LastLast
Results 1 to 20 of 56
Thread: LML Exhaust Regeneration
    Alvin, TX, USA
    Default LML Exhaust Regeneration
    Whenever the exhaust regen occurs on my 2012 3500HD Duramax, I have noticed 2 things. One, idle speed increases about 200 RPM; and two, fuel mileage steadilly decreases for the 20 minutes or so regen occurs. Running empty, fuel mileage will ultimately be reduced 2 to 3 mpg. Will regain perhaps 1 mpg (at best) of that loss before next fillup. Is there any way to reduce that mileage impact?
    As soot builds in the DPF, exhaust restriction increases. The rate at which soot accumulates depends on several factors, with exhaust temperature being one of the bigger factors.
    Those who tow or run at freeway speeds for longer periods see fewer active regenerations. While towing, exhaust temperature could be high enough that the soot is being consumed at nearly the same rate as it builds in the filter.
    Cooler temperatures that occur during the winter months compound the problem - if you can call it that. If you know that you'll be driving around town or locally in cold/cool temperatures, you might be better off driving some other vehicle, if one is available. The only downside to driving a DPF -equipped diesel pickup during such times is a hit to fuel economy because of the active exhaust system regenerations.
    Alvin, TX, USA
    Is there any kind of notice given by the DIC when a regen is occurring? I have not seen one or found one. Just noticed the mileage dropping or idle speed being higher. Am I missing something? Think I read that Ford tells you.
    Nov 2012
    St. Augustine, Florida
    I don't think it tells you anywhere. The only way I know is the elevated idle and the motor actually sounds a little different during acceleration.
    2012 3500HD Silverado LTZ Duramax 6.6 Dually 4X4 pulling a
    2012 Keystone Avalanche 341TG in the quest of happiness!
    Proud member #980 of The 3500 Dually Club
    It only tells you if it's PO'd. It nags you to drive if you let it get loaded by excessive idling etc. Essentially if it gets too much soot load it nags you to drive in order to do a proper regen.
    You can often smell at the rear of the truck when it's in regen also.
    I've been working on "emissions intact" tuning for the LML and have been having pretty good success so far with MPG, responsiveness, a good bit of power on demand, PLUS I had a pretty decent run between regens during unloaded highway driving.
    Been monitoring the regeneration and need to do some studying as to the triggers as last regen was long on miles, but at a low soot accumulation.
    Apr 2004
    Bar Nunn, WY
    I think it starts at 700 miles or 44 grams of soot (at least on my LML).
    Jay
    2023 Tahoe 3.0l diesel
    2013 Harley Switchback
    2021 Ram 2500 6.7l (sold)
    2018 Chevy Traverse (sold)
    2021 Silverado 3.0l LM2 (sold)
    2019 GMC Sierra 6.2l (sold)
    2019 Colorado ZR2(sold)
    2017 2500HD CC D/A (sold)
    2015 1500 CC High Country 6.2l (sold)
    2010 Chev 2500HD CC D/A (sold)
    2013 Chev 2500HD CC D/A (sold)
    2006 Chev 3500 CC D/A (sold)
    2005 Harley Ultra Classic (sold)
    I believe from what I have been reading is that there is a 700 mile component to this as well as differential pressure/soot load.
    Mine was doing mid 300's but last one was at 700 and only 24g soot load at the time it started. It finished in 34 miles but dropped the DIC MPG very little then started to recover quite quickly.
    Apr 2004
    Bar Nunn, WY
    My truck regens between 400 and 700 miles on summer fuel. It drops with winter fuel. Here in MN, summer diesel is all B20 which may help with longer times between regens. Winter fuel is B4. The 700 miles bugs me. It a total waste of fuel to go into regen just because I went 700 miles since the last one. I can actually watch the soot load drop on it's own when I'm towing heavy (no need for active regen).
    I would really like to have my truck reprogramed, but can't afford to loose the warranty. I don't need any more power, but it would be nice to get a little better mileage. I may think a little different after the truck get closer to the end of the warranty.
    Jay
    I put 120K miles on my last 2009 LMM, only had it bother me about a regen once that I recall.
    Most of the time they must have happened while towing, and since my average MPG loaded/unloaded hovered in the 12s, it wasn't really noticable.
    The more you tow, I guess the less of an issue the DPF is. I was amazed at how clean the tailpipe remained over time...basically ZERO soot accumulation, indicating that not much makes its way out.
    What I have observed is that a typical regen cycle yields about 12mpg empty based on the DIC average. The longer the regen, the more your avg MPG will drop.
    As for the tail pipe soot, remember, the big air gap allows lots of air through and it tapers outward so there's not much contact with the walls. Look back inside the main pipe and you'll see some black.
    Alvin, TX, USA
    Default Exhaust Regen
    Guys, especially John, my 2012 regens about every 250 miles empty. Some of you get 400 to 700 before regen?
    I'm still getting consistent 700 mile regens at about 24 grams soot load. If I had the ability to extend the regen miles through programming I'm sure I could get close to double the miles before the max soot load is reached. While double 24grams is 48, the base soot after regen always pops back up to several grams minimum shortly after the regen cycle is complete.
    I had an email conversation with a customer who thought he was getting long regens. He went on a trip and found it to be in the 200-350 range.
    Oct 2000
    Defiance, MO USA
    I just made a verbal commitment on a 2014 2500HD Duramax. I have been hunting for info on fuel mileage posted on the web. I have high hopes the 2014 will get better MPG than my current 2001 which is around 16mpg. Now I am worried after reading this thread. I seldom haul or pull anything. I bought/am buying a 2500HD diesel because I like the power and hate transmission downshifts on lesser vehicles every time you encounter a slight grade when cruise control is on. Since I won't be working the engine hard I will probably have frequent regens and my MPG will suffer.
    2014 K2500HD Crew Cab LTZ Duramax / Allison 4x4
    Aug 2003
    Tucson, AZ
    Those of you who can tell when your vehicle is in regen mode, how do you know? The only time I ever knew my '09 needed regen is when it told me I needed to do it. That was because I was driving only around a campground for two weeks. Do you think perhaps the reason I don't know it is because virtually all the time I use the truck, I'm carrying a 4k camper and towing a Jeep Wrangler?
    Bob
    2009 LTZ 3500 D/A ext-cab DRW
    1993 11' 3" Lance cabover camper
    Feb 2014
    Loveland CO
    How do you find out your soot load, does it say in the DIC?
    Soot load is monitored in the scan data.
    I encourage my tuning customers to start with the Edge Insight: http://www.kennedydiesel.com/detail.cfm?ID=673
    The Insight is used to monitor the soot load among other things. It is also a useful coach in that when you see it beginning the regen mode you can drive accordingly. In my case knowing that the regen is coming every 700 miles like clockwork is also helpful. Whenever possible I try to plan to be on the highway when this comes around.
    Oct 2000
    Defiance, MO USA
    Default The picture tells it all
    With about 450 miles on the odometer this was snapped after an hour at 70mph with cruise on. This is what makes me question a good many folks who claim they get 20+mpg. I don't think my new baby would get that going down hill with a tail wind.
    Feb 2014
    Loveland CO
    I have a Edge Insight that I had in my old truck, I got it last year, it is version REV 04 with a build date of 05/2011 also has this number as well# H00001700. I can not find the soot load on my devise, if it is not the latest version I believe I can download the newest version to my Insight, is that correct? I just want to learn all about this regen business, also will my motor noise be louder during regen? Today my injectors were real loud at around 2100 RPM to about 2400 then it got quite again. Thank you for your patience this new truck is a hole different animal then the LB7 I have been driving for 12 years. I am very interested in buying your tune when your ready to release it.
    You'll want to go to Edge site and download their Fusion program to update your unit.
