Results 1 to 10 of 10
Thread: Is my turbo about to die? 2007 LBZ w/7000 miles
    Mar 2001
    Smith Center, KS
    Cool Is my turbo about to die? 2007 LBZ w/7000 miles
    Hello all-
    Quick question concerning my 2007 with 7,000 babied miles. I have noticed that immediatly after I shut the engine off and walk around the front side of the vehicle, I can hear a rumbling noise, that slowly tapers off. I am almost sure this is the turbo coming to a stop after the engine is turned off. I have never noticed this sound before, with this truck or any of my previous duramax's. It sounds kinda like rocks rolling around inside a tin can, that slowly diminishes. Is my turbo bearings on their way out? What do you dmax guru's think?
    Thanks in advance!!
    ** ccole **
    Past Rides: 1978 Chevy 5.7 Dsl; 1982 C-20 6.2L Dsl; 1984 Chevy 6.2 Dsl; 1986 Suburban 6.2L Dsl; 1989 K2500 6.2L Dsl; 1994 F250 7.3L; (2) 1997 F250 7.3L; 2004 Duramax; 2005 Duramax; 2006 Duramax; 2007 Duramax; 1995 6.5 Non-Turbo; 1994 6.5 Turbo; 2001 F350 7.3L, 2005 GMC Duramax (Current)
    bayville, new jersey, USA
    my 06 lbz makes the same noise...about 9k on odo...i dont think it s anything to worry about....least hope not!
    '12 gmc sierra 2500 dmax slt carbon black.
    '12 s350 diesel mb
    '10 mazda 6i, for sale
    '77 450sl benz, in family since new, sold, still in jersey thou
    '91 350sdl benz, 3.5l diesel, 28 mpg
    '90 560sel benz
    Jan 2007
    my 07 classic is doing the same sine new. now i have 2600km on it. I don't think it is the turbo, sounds more like a air condition compressor to me or the coolant fan.
    Dec 2004
    Ontario
    One of the first things I noticed on my '07 LBZ was that sound. It has done it since new and it now has almost 8,000 km on it. I never noticed it on my '03 LB7.
    2007 2500 HD Classic cc/sb, Diablo Predator, 285/75R16 BFG AT/TA's, Advance cover, XM, Garmin GPS
    Nov 2003
    Davenport Florida
    I hear the same noise on the 07 LBZ I just got yesterday. It has 247k on it, I was thinking the turbo might be bad, but now I dont know.
    email rfkjr@juno.com
    07 2500HD C/C LBZ 248k
    83 K2500 X 6.2, now 390 Stroker,18.5 & 19.5x 44 TSL\'s & Boggers,5.13w/Det.Lkrs. Mud Toy
    90 ISUZU, 350 eng, 350 trans, Double xfer cases, 2.5 Military Axles, Tractor tires
    Dec 2005
    Klamath falls/keno Oregon
    Its the turbo winding down..its a good sound
    Hummer wheels :^)
    dual lift pump
    Banks air intake
    Dec 2002
    Teton Valley, Idaho
    Scooby, I'll bet it is the air conditioner coolant pressure relieving itself through the evaporator valve. I hear it on my '05 as well.
    Turn off your AC, go for a drive (without the defrost setting putting air on the windshield because IIRC that defaults the AC to ON) and see if you still hear the sound on shutting down.
    Nov 2003
    Davenport Florida
    Its not the refrigerant equalizing in the system. I know that sound well. I havent been running the air either. Its the turbo rumbling. Sounds like it needs grease. I'll look for the grease fittings. (Just kidding.) I ve been trying to get my Ultragage to work in this truck so I can watch boost and other parameters, but so far I cant get it to power up from the OBD port. Also my lighter outlet doesnt work. I wonder if a fuse is blown.
    Quote Originally Posted by Scooby View Post
    On these newer trucks they have a panel where they ganged the turbo zerks along with the ones for the muffler bearings and the blinker fluid filler neck. Just look for the blinking LED's to locate it!
    Nov 2003
    Davenport Florida
    I found the cig lighter fuse blown under the hood. Replaced it and now OBD port has power, and ultragauge works. I haven't looked at all the gages it can display, but I did see boost psi and fuel rail pressure.
