Results 1 to 12 of 12
Thread: Bucking-Fishbite Under Load- Again and Ongoing
    May 2004
    Salem, Oregon
    Default Bucking-Fishbite Under Load- Again and Ongoing
    Hi Folks- Its been awhile, but still having ongoing problems with bucking under throttle while warm and fishbiting at steady state at times.
    Had my 99 out yesterday and under load (going up a 1600ft grade- Little hills in Oregon on the Coast range) at 55-60, the engine surged and bucked...I took my foot out of it and maintained the hill at a slower speed, but it definitely felt starved of fuel.
    As I got to the end of my trip, a few times accelerating from a stop and performance was way down.
    I am getting boost on the hills ( upwards to 7psi or so). I ran yesterday without my Kennedy boost fooler as I hadnt put back on and recalibrated yet after the IP was replaced.
    Recent history- Last fall had the IP replaced, the optical sense ring had broken. Tech timed and set base timing. Starts and runs great, maybe a bit more smoke on startup than before, but it sits a lot.
    Lift pump is a new GM. It is putting out barely 3psi with the engine off. Doesnt move the needle when the truck it idling.
    Flow is good from the lift pump with engine off and engine doesnt sputter or die when I open the bleed handle while its running.
    Engine Fuel filter is new.
    Fuel is clean and new, tank was 3/4 to full at the time.
    No sock in the tank.
    When opening the fuel cap, I hear a "whoosh" - dont really know if it is pressure or vacuum.
    Have experienced the problem prior to even replacing the IP.
    Having been around in circles on this for the last several years, it just seems like it just doesnt get enough fuel for when there is a demand.
    I did notice last night that it doesnt appear to have the Optical encoder Filter on it, which I thought was standard for the 99. But in any case, that might explain the fishbiting, but i dont think the load performance would be the case.
    I am really leaning towards a higher volume, higher pressure lift pump as I am at a loss to explain the power loss issue.
    It definitely did this after driving for the first 75 miles yesterday and getting it warm...I am going to try to take the fuel cap loose and repeat, thinking maybe the tank is getting a vacuum and not being pressurized....
    Any thoughts?
    BrentN
    1999 Suburban 2500 4x4
    176,500 miles,4.10,K & N Air Filter
    Kennedy 3.5" Exhaust, Remote Mounted FSD Cooler
    Kennedy Boost Fooler, Homemade Intercooler (Dieselpage Model)
    Derale Fan Cooled Tranny Cooler (under body mount)
    A Pillar Pod (Isspro Boost, Pyro & Trans Temp)
    2014 Cruze 2.0 Diesel- Tuned and loving it.
    Kerma TDI Tune (+35hp/75lb-ft).
    55.7 MPG best average thus far
    2008 Grand Cherokee, 3.0L Mercedes Diesel
    Tuned- 240hp/440lbs - Amazing out of a 3.0L
    1998 Dutch Star 38' Diesel Pusher, 8.3 Cummins, Allison 6 spd, 9.9-10 mpg
    Stock 300 hp/850 ft-lbs
    Replace the fuel cap. Revisit the diagnosis if that doesn't cure it. More often than not, it does. It's strange, to me, that some people will pass on the simplest, cheapest solution in favor for more complicated and costly wild goose chases. If it doesn't fix it, it was due for replacement, anyway ("whoosh" = bad pressure vents). Make sure the replacement is "Diesel Fuel Only". Gasser caps don't vent properly (they "whoosh", and cause bucking-fishbite).
    3 PSI fuel pressure at idle is adequate. 4 PSI is the spec. If it doesn't stall when the bleed (or drain) is open, the LP is not likely your problem. A higher flow/pressure fuel lift pump IS NOT a solution. If a good OEM LP can't do what it needs to do at/near stock power levels, the problem is elsewhere.
    Removing the fuel sending unit sock is not a solution. The correct sock should have NO affect on fuel flow. It not only strains the incoming fuel, and it decreases the fuel inlet velocity, which in itself, helps prevent plugging if a little garbage is in the tank. If it plugs, the problem is NOT the sock. If you have an aftermarket sock (such as a "gasser style") installed, all bets are off. Simplify things by doing it right the first time. The OEM sock should look like a mesh tube, with a flat end (which may include a flapper valve). Unacceptable aftermarket socks have typically looked like a slightly inflated, flat envelope, and these WILL fail with the slightest viscosity increase or debris.
    Don't assume you have perfect fuel in the tank, even if it is relatively new. Pull a sample from the water drain (T-valve at the T-stat housing). Let is stand undisturbed in sunlight for a couple hours in a glass jar. Any water or debris should settle in that time. If it darkens, you have something growing in it (algae).
    May 2004
    Salem, Oregon
    DmaxMaverick- Thanks Much for the advice.
    I will swing by GM and see if they have a new cap and as a short term measure at least loosen the existing one. If it will only be that simple of a solution, that'll be awesome.
    I will pull some fuel into a mason jar this evening...Good trick on setting it in the sun for an algae check. Anecdodally, it is nice and green when I am opening the t-handle...no water or debris, but the sit for several hours test will certainly bear out if I have something in solution.
    The cap is the original green cap and have had it on their since 2003 when I purchased this rig.
    Like the fact that you had a cruze...I took the $ the VW was offering and made out like a bandit in getting the cruze...78k on mine, have seen 55.7mpg in the last month...It should do much better once it warms up before the AC has to come on
    Thanks again for your fast response, that is what I love about this forum!!!
    BrentN
    A 15 y/o fuel cap is always suspect.
    We loved the Cruze. Is yours a Gen 1 or 2 (2017+). 50+ MPG was a cake walk. Got over 60 at times (and 70 more than once) in the spring/fall. Just racked up too many miles too quick. New(er) car going at near twice the rate, but will probably keep it a bit longer. These things are getting too expensive to flip every couple years!
    May 2004
    Salem, Oregon
    I replaced the cap this morning...Proof will be in the pudding if it resolves it. Curious, the old cap and the new cap will allow air to be sucked through them, so I am not too optimistic that it will be resolved, but at least one more item checked off the list.
    My 2014 Cruze is the 2.0, Not sure the Generation. It had a bit of turbo lag when I got it, a bit of hesistancy off the line, that unsure feeling if it was going to actually take off. The Kerma TDI Cruze Tune I got for it did wonders. Its the one that adds 35hp and 75lbs torque, it isnt the hottest tune, just perfect if you ask me.
    In my current job I am putting on about 200 miles a day. It does seem to run about 10mpg lower in the morning when its cold, but the afternoon it really picks up. Seems to be more temperature sensitive than my 2011 Jetta TDI.
    Its got 78k on it now. Going into GM monday for the 2nd level recall for Nox sensors. Had to return it to stock tune then will put back.
    Thanks for everything.
    I will let you know how it goes.
    Brent
    BrentN
    When was the last time the injectors were serviced ????
    Any codes showing ???
    I agree with Maverick on the simple things first.
    A flaky injector can cause issues.
    The smokey start up is suspect.
    Poor pop pressure on injectors and worn out nozzles can be a cause.
    Normally on an OBD2 TRUCK a dropped cylinder will set a code...butttttttttttt you can't count on it.
    May 2004
    Salem, Oregon
    Robin,
    Thanks for the input. The injectors were replaced about 75k ago. The engine actually only has about 90k on it, as GM replaced it just before I purchased it.
    I was able to spend some time yesterday on it. I had replaced the filter last fall and the truck sat most of the winter. I had been quick to ASSUME the filter was still good having "just" replaced it.
    I took DmaxMavericks advice and put a sample of fuel into a clear mason jar. What looked clean and green out of the hose turned murky and had floatys in it...algae.
    I popped the "recent" filter to find it brown and coated with crap- Photos below. The Fuel manager bowl had a bunch of black algae in it. Which took some time to clean.
    I put some Power Service Diesel Clean into the tank, replaced the filter, cleaned the housing as well as pulled the IP inlet strainer and made sure it wasnt plugged.
    Went out to Spirit Mountain today from Salem and Zero performance problems. It felt like one fishbite bump on the way but the engine ran great except for that. Power was back in full force.
    I am planning on running the remainder of the tank of fuel out and drop the tank in the next week or two and give it a good scrubbing as well as blow lines and swap filters and clean the bowl again. I am sure there is still more in the system, but needed to drive the Burb today.
    From my reading it was enlightening to find that algae is on the rise with the 2007 change in sulfur content in diesel. Apparently the sulfer helped abate algae in the past.
    Knowing this, I need to go get some algaecide dumped into my 150 gallon tank on my diesel pusher. It sits all winter as well.
    In the photos below...The cloudy jar is before replacing the filter and the clear jar is after. Pretty stark. These sat in the sun for a few hours.
    In the single jar photo, you can barely see the fuzzys in the bottom of the jar, but you could definitely see clear looking stuff floating in solution as the diesel was going into the jar.
    Like Dmax advised...check the basics...I would have bet my life that my filter was clean since I had replaced it last fall.
    I do appreciate everyones help. Have a great Easter
    BrentN
    That looks like a lot of water, probably too much for PS to handle. Long off-season periods leads to condensation, not including what you pumped in at the fuel station. If the vehicle(s) are stored for long periods, it's better to have the fuel tanks full. Full tanks have less air in them, and less internal surface area exposed to air.
    Stock up on fuel filters. You'll need them frequently for a while, even after cleaning the tank and lines. Adding biocide to the fuel kills the creatures, which is a good thing. The dead creatures in the system will continue to plug up things for a while.
    Ft. Wayne, In.
    How can you effectively clean the inside of the tank with such a small hole?
    I'm curious 'cause my 2 door Tahoe sits all winter also.
    Dave, N9LOV
    Member #242
    Dave's Diesels:
    '97 2 Dr Tahoe, Intercooled,
    Kennedy ECM, 4" Exhaust
    '02 GMC
    May 2004
    Salem, Oregon
    Hello,
    In the past its done by dumping all the remaining fuel out into a storage container and getting in there with your arm and wiping it down. Depending on how it looks I may dump some gas in as a solvent and swish around and then completely cleaning back out.
    With these Suburbans and their 42 gallon tank, a transmission jack works the best for putting it back up in.
    BrentN
    Ft. Wayne, In.
    Thanks Brent. I'm thinking the gas option is a good one. My guess is that my relatively big flat 30 gal tank will be harder to get all of the gunk out of than your relatively tall fender tank, as it might be harder to get all the gunk piled up on one spot to absorb or suck out.
    I know I need to do it though...
    Thanks again,
    Dave
    Dave, N9LOV
    Member #242
    Dave's Diesels:
    '02 GMC
    Get the contents out of the tank... Add HOT water and dawn soap.
    Slosh the mixture real well to help clean the tank.
    Dump the contents and flush with clean water to clear the remaining soapy solution.
    Dump the tank..
    Flush a second time.
    Stand tank up and allow any remaining water to pool in an accessible corner.
    Use rag on a stick to sop up the drizzle that's left.
    Reinstall tank and add clean fuel.
    Run lift pump to purge line from tank.
    Install new filter.
    As Maverick said...couple extra filters would be in order.
    Run engine and open purge drain valve and let some flow to purge things a bit more.
    Getting the tank empty and washing it, plus adding new fuel should do the trick.
    Good luck
