Results 1 to 8 of 8
Thread: Banks Sidewinder turbo on my 6.2L Hummer?
    Sep 2008
    San Juan Islands, WA
    Default Banks Sidewinder turbo on my 6.2L Hummer?
    Well it seems that the idea of adding a 6.5L turbo system is just too much so I've abandon that idea. I was just offered a Banks Sidewinder turbo for the 6.2L diesel.
    Will this fit my Hummer, a '93 with the 6.2L diesel..
    I am doing other research as well but hoped someone here may know the answers as well..
    thank you
    Steve
    The sidewinder won't fit, for the same reasons the 6.5L won't. You'll have to use a 6.5L or Banks turbo van (still some modification), GM Hummer setup, or fab your own. Peninsular has an answer, too ($$).
    Concord, NC, USA
    Mark Chapman DP member #653;
    1983 K2500 6.2 Suburban, 4" lift, 35" tires, ATS turbo, Banks exhaust/intake, pyrometer, tachometer;
    1986 K5 6.2 Blazer, 2" lift, 33" tires, Banks intake, pyrometer, tachometer
    1963 wife, one owner, average mileage for the age but in excellent shape, a keeper
    1992 daughter, low mileage, pretty, limited edition, but requires some money to maintain
    1995 son, sports model, very fast & peppy, time will tell on durability and maintenance costs
    "Grease is good"
    Lubbock TX, USA
    Banks made a Turbo kit for the H1 Hummer 6.2 or 6.5 N/A engines up till '95 models.
    It's very similar to the truck setups, but modified to fit the Hummers.
    I have an almost complete kit sitting in storage that I'm not thinking I'll get to using any time soon (No Hummer). It has the coveted TE06H turbocharger with it too.
    I think it would work with the 6.2L, but it was made for the 6.5 I believe. I don't know if this still available from Banks at any price, but call and find out.
    I might be intersted in moving mine, interested?
    Gatheringsome $ for a Full Race 4L80E conversion for the drag strip pickup...
    1986 C10 SCLWB 6.2TD 3.73 700
    1989 V20 SUB 6.2NA, 3.73 400
    1994 G20 VAN 6.5NA, 3.42 60E
    1996 K30 DRW 6.5TD 4.10 80E
    Sep 2008
    Hi John,
    I'd like to hear more about your system. The factory 6.5L turbos were mounted to the rear of the engine. The Banks sidewinder mounts on top / to the side of the engine near the air lift hook. Where does your turbo system mount? Is it a Banks Sidewinder?
    I don't know anything about the TEO6H turbo other than a quick WWW search shows it's made in Japan.
    Tell me more and of course-how much?
    The guy wants $800 for his used Sidewinder locally. I think thats a bit high for a system made in the mid 80's and will still require me a lot of work to get it to fit/work.
    On either turbo system, you would probably have to raise the Hummer body 1" off the frame for clearance prior to the new 'additions'. AMG did so, when they went to the Turbo 6.5L engine.
    When I spoke with Banks a few years ago - they said "no, it would not work" "we don't make a system for the '93 Hummer" and weren't interested at all in trying to get me a system to make it work - they were actually quite rude.
    [B]'93 Supercharged Hummer[/B]
    [SIZE=1]([I]the ORIGINAL).
    [/I][/SIZE]
    Jun 2017
    USA ohio
    Default H1 banks kit
    I am looking for John 8662 I have a question or 2 about the pls Banks H1 kit. Please contact me
    Click on his name in his post above and you’ll have the option to PM (private message) him.
