TheDieselPage.com Forums
2018 - TDP's 22nd Anniversary
Go Back   TheDieselPage.com Forums > The Diesel Page Member Forums > 6.5L Turbo Diesel
6.5L Turbo Diesel 1992-00 6.5TD - Discussion forum for the 6.5L engine.
Reply
Thread Tools Display Modes
  #11
Old Yesterday, 02:08 PM
JohnC's Avatar
JohnC JohnC is online now
Enemy of the State
How are you determining that there's a ground in the glow plug harness? IF you're measuring it with an ohm meter, the glow plugs are such low resistance that they will be indistinguishable from a short to ground. You need to disconnect all the glow plugs first.
That said, if the glow plugs heat then there's no short in the harness.
Why do you think the glow plug circuit is causing the battery to go dead?
I went back and looked at your original post. The problem was that the starter was buzzing, right? Was that caused by a dead battery? A buzzing starter can be caused by a bad (high resistance) ground. This problem will not lead to a dead battery, though. And, I don't think there's anything in the glow plug circuit that will drain the battery when the key is off.
__________________
"Need" - Wanting to get someone else's money.
"Greed" (formerly meant what "need" means today) - wanting to keep your own.
"Compassion" - a politician's willingness to arrange the transfer.
-Joseph Sobran
Current oil burners: MB 350SDL, Kubota 7510
Gone but not forgotten: '87 F350 7.3, '91 C2500 6.5, '95 K2500 6.5, '06 K2500HD 6.6
  #12
Old Today, 09:47 AM
gsimpson gsimpson is offline
Enthusiast
Default Answer
I used an ohm meter at the back of the fuse box, it says there is a short with no key in the ignition and no batteries in the vehicle. When I touch it to the lead that is pluggeed into the glow plugs it also reads there is a short.
So you are saying that the glow plugs always show a grounded state?
__________________
1995 Chevy 2500, 6.5L Diesel mostly stock 234,000 miles. Changed the water pump to HO WP, deleted the vacuum pump and added a mechanical wastegate controller made by me with info from others on the forum.
  #13
Old Today, 11:31 AM
JohnC's Avatar
Enemy of the State
Quote:
If you measure from the glow plug harness at the relay to ground you will see about 0.1 ohms, hard to distinguish from a short.
If you're using an ohm meter on the fuse box, I hope you have the battery disconnected, or are on the circuit side of the fuse box with the fuses removed.
__________________
-Joseph Sobran
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
