Results 1 to 2 of 2
Thread: AIR BAG IDIOT LIGHT
    I added a back up camera and monitor to an existing switched power lead which I tapped off of a wire back in the fall of 04 when I purchased my 2500 Siliverado crew cab,I appearently blew a fuse,no power and now the Air bag idiot light is on the upper left side of the instrument cluster, I did not see any reference to a fure to cover the air bag in the manuel,Can someone tell me what fuse or what to check? Is there a easy source for switched power? I believe both cigerette plugs are live all the time , Thanks in advance
    jbplock Guest
    There is a SIR fuse (supplemental inflatable restraint) in the under hood fuse box..
    I taped this fuse to supply power to my lift pump timer using a Littlefuse “Add-a Circuit” purchased from Autozone.
    The RUN-START circuit supplies the SIR/Fuse circuit, which is active when the key is in the Run or Start position.
    More pics (2 pages)
    [img]smile.gif[/img]
    [ 02-01-2006, 03:42 PM: Message edited by: jbplock ]
