Page 3 of 5 FirstFirst 12345 LastLast
Results 41 to 60 of 87
Thread: High Miles Contest!
  1. #41
    Well we have (2) 94 Subs 4X4
    One has 261K on the original engine and the other has 255K
    One just tossed a head gasket a couple days ago so its coming down for a rebuild.
    It has had amzoil in it since new and we are the scond owners so it may be good shape.
    I am going to bless it and run it some more
  2. #42
    Dec 2002
    Teton Valley, Idaho
    this is all good news as my truck just turned 195K young. Looking for another 195,000...
  3. #43
    Default 6.2l in half ton 1988
    I just bought my old truck back. I bought it the first time at an auction with 140,000 miles. I ran it to work 90 miles one way for some time. I sold it the other year to a farmer with 211,000 miles. It took him 12,000 miles to bump the TV cable loose and burn the transmission. Now with 223,000 miles transmission was dropped this weekend to be rebuilt.
    Have a bet with my father that the engine will not see 300,000, I hope to do it with Biodiesel I make in the shop.
  4. #44
    Default High Miler 6.5
    I have a 1993 GMC 3/4 pickup with the 6.5 TD. 222,000 miles on original engine and tranny.
  5. #45
    Jun 2006
    Richmond UT
    I hope mine lasts half as long as some of you guys! But I just won the low mile contest 95 with 50,0XX
    95 K2500 Silverado regcab, 6.5L F-vin, 4l80E, HD alloys 3" turbo back, Air intake, custom machined FSD isolator & I just turned over 50,000 original miles SOLD!!!
    79 Toyota Hilux 20R, G52 5-speed swap, 4.7:1 t-case gear reduction, 4.37:1 R&P's, and 35" X-terrains. Too bad the poor thing is about to die from skin cancer
    86 F250 Lariat 4x4 6.9 diesel, 4 speed, 3.55 gears, and lovin it
  6. #46
    320,000 on my 1994 C1500 ext cab with the original 6.5 TD. It looks like the drivetrain will outlive the rest of the truck and is probably worth more...
    1994 GMC K1500 6.5 TD 185,000 mi
    1994 Chevy C1500 6.5 TD 320,000 mi
    2001 Chevy 2500 HD Duramax 105,000 mi
  7. #47
    Thanks for posting the info about all of your high-mile 6.5's. We'll run the contest through to the end of this month, then we'll select that truck/Sub with the highest mileage, then request a digital photo of the odometer and vehicle, along with a little history.
    Thanks,
    SO, who's the winner!
    Maplesville, AL - Home Base
    Default '98 Suburban 6.5
    It was still bone stock, except for Kennedy's FSR Remote Mount, when I sold it to my son in law a month ago.....245,000 miles. All original, engine, tranny, turbo.....everything except injectors which were replaced at 150,000. Ed
    Ed
    KM4STL
  10. #50
    cleveland, oh
    Default 202,000 Miles on original engine...then thermostat stuck..
    I had 202,000 miles on my 95 w/ stock 6.5l ...then thermostat stuck....head cracked...new heads installed ...and main bearings went...now used motor w/40,000 miles....hope to go 202k on this one also..
  11. #51
    May 2006
    morganton.N.C.
    Talking
    289k on 94 blazer 6.5l turbo been runing good till now
  12. #52
    Dec 2002
    grayson, georgia
    Default 223,000
    223,000. 1994 gmc cc dually i got in 2000 at 139,000. since then i've put on the kennedy fsd cooler kit at about 150,000 located in front of the driver's side headlight. this module is crapping out now, other fixes have been the
    output shaft speed sensor which did in the speedometer and put me in limp mode, batteries and brakes. all in all, i still love the old truck. gonna put new glow plugs in before winter and get the new module.
  13. #53
    Sep 2006
    Scottsdale, AZ
    Default Miles High
    Got a '94 6.5TD Burb 2500 that's my wife's with 205,000. BUT are you ready for this... I also have a 94 Dodge GAS engine 1500 PU with 265,000 on the original engine and it runs like new!!! Thanks for the synthetic oil for all those miles.
  14. #54
  15. #55
    Aug 2001
    newark, de, usa
    Thumbs up 96 Sub
    96 Sub 2500 6.5 with 308,000. Original engine never opened for repair. Lots of other stuff like pumps etc. But still strong no oil burn.
  16. #56
    Smile Close but no cigar
    My 97 4x4 pickup just rolled over 300, 000 last week. Original owner, 3 or 4 Ip's, couple starters, one computer module, the rest is original. Drive to work every day. Couple trips to Chicago from Michigan. Couple trips to NC, Atlanta, PA and up north deer hunting. Still getting close to 20 mpg.
    97 6.5 1500 EXT Cab shortbox 4x4, Auto trans, 3.73 gears, 4" Exhaust 400,000 miles
  17. #57
    I had 267,000 on an 95 last year when it was totaled when someone ran a red light and hit me on the passanger front wheel. The good thing was the plastic on his Honda kind of exploded all over.
    I am currently looking for another, 97 or newer.
  18. #58
    Jun 2006
    Surrey, BC
    Thumbs up
    I love my '96 k2500! I bought it in May '06 with 327,000 km. I'm about to turn 340,000 km. I was told it's original, I'm the 3rd owner. I just replaced the IP last month, and the truck runs and drives tight and solid. I had a 93 Dodge for 3 years right before this truck. Although it had only about 97,000km when I bought it and 147,000 when I sold it, the Chev drives way smoother! The Cummins was definately a stronger mill, but the rest of the package doesn't nearly compare. Cheers! Brett
    2005 GMC Sierra SLT Dually Crew, 4x4, stock
    71,000 kms
  19. #59
    243,000 on my 1994 K2500 ext cab. (43.000 after overhaul).
  20. #60
    Nov 2006
    Kelowna, BC
    Default Milage
    311,000 on my 93 6.5 and never been apart.
