Results 1 to 8 of 8
Thread: Cam Broke at 138225 miles
    May 2002
    Rogers Mn
    Default Cam Broke at 138225 miles
    Coming back from up north deerhunt and sudden clatter and dead . Garage remove front cover and valve cover all push rods bent and cam gear turning but not cam . Had a GM long block installed..
    2002 Silverado DA combo 4 whl CC.
    New longblock 138252 Miles , Sill protectors
    Husky flaps
    SS Nerf Bars , Access Cover\' Coverall mats ,Lovern smoked bug shield , Dual Power Seats ,W,T.Tinted Vent Shades
    http://www.picturetrail.com/deerhunter7
    Ft. Wayne, In.
    It would be interesting to hear a little more about this failure deerhunter. Any other info available?
    d
    Dave, N9LOV
    Member #242
    Dave's Diesels:
    '97 2 Dr Tahoe, Intercooled,
    Kennedy ECM, 4" Exhaust
    '02 GMC
    May 2002
    Rogers Mn
    Default Do not know the cause
    When you spun engine there was no compression . Cloquet Auto Service did the diagnose and engine [long block] was installed . Did not pay for me to have them tear down farther . They called GM and they also recommended a long block or complete engine replace .
    Husky flaps
    As far as I know, DMAX hot tests every new engine. I was there in 2001 and watched as they ran a series of complete drop-in engines through a hot test. That test stressed the engine enough that it would find a lubrication problem before it ever left the facility. That said, I wonder if long-blocks are tested?
    I would be more inclined to believe that the cam pin sheared than the camshaft broke.
    Dec 2004
    Texas
    Default Cam broke?
    Never heard of a Dmax breaking a cam, I've had mine turning 4500 rpm's and no problem. Yours is the first I've heard about, you didn't hydrolock it in flooded water did you?
    May 2002
    Rogers Mn
    Had new injectors 30,000 miles ago . Was running great up to the point of sheared pin or broken cam..
    Husky flaps
