View Poll Results: Your 6.5 highway fuel milage?
Voters
562. You may not vote on this poll
  • less than 12 MPG
    7 1.25%
  • 12-13 MPG
    28 4.98%
  • 14-15 MPG
    72 12.81%
  • 16-17 MPG
    133 23.67%
  • 18-19 MPG
    107 19.04%
  • 20-21 MPG
    64 11.39%
  • better than 21 MPG
    49 8.72%
  • Just looking
    102 18.15%
Results 21 to 40 of 60
Thread: 6.5TD MPG Hiway mileage Poll!
  1. #21
    16gaSxS is offline Moderator, Have Shotgun & dogs will travel
    May 2002
    Great Falls, MT
    Quote Originally Posted by Michael Cain
    Were sorry to hear that you are in canada vote to become the 52nd state JK.
    This one has me perplexed?
    But I am confuse easlie.
    95, 6.5, C-2500 extended cab shortbox, Auto transmixer 3.42 diff, Jardine exhaust system
    FSD Cooler replaced w/ Heath PMD Isolator
    Heath Turbo-Master Boost Controller, Max E Tork chip '97 cooling upgrades, Kennedy Fan clutch,
    Glow Plug over ride,DeeZee 38.5 gallon Aux fuel Tank 225K miles and rolling
    1994, 6.5 Blazer, 3:42 diff, 4 inch exhaust, Heath PMD Isolator, Heath Turbo-Master Boost Controller Max E Tork, Heath SB intake filter system.
    221K miles and rolling.
    Diesel Page member #81
  2. #22
    Question
    Uhhhh. Yeah.....
  3. #23
    Aug 2006
    WV
    Quote Originally Posted by 16ga SxS
    I think that they are counting Iraq as the 51st state....I Guess
    Shane
  4. #24
    Sep 2006
    Brooker, FL
    Well, I get about 9.8 mpg, but then my 6.5L TD is in an 18,000 lb. class A motorhome.
  5. #25
    Jun 2006
    Okanagan BC, Canada
    I have a 93 2500 extended cab long box, 2 wheel drive, 4l80e trans, 3.42 gears non posi full floater rearend, tires are 265/75 16 ltx michelins, F engine, original pump and injectors with 170,000 miles. Its getting 20mpg on the US gal.
  6. #26
    Dec 2006
    NJ
    I looked at this thread briefly, I have a couple questions. I'm running a stock 95 GMC Sierra 6.5L Turbo diesel ext cab 6ft bed automatic trans with 152K miles and my truck rides on 315/70/17 in tires with completely stock gears to my knowledge. Normally In town I get about 11-12 miles to the gallon and I have mainly stop and go and some highway, mostly on and off the brakes. I do a little better on the highway, but not a whole load, maybe 2 mpg better. What is the standard PSI that these truck's turbos push.? I don't know as I just found the wastegate actuator on mine is shot and was wired shut so it would boost. I have no Idea of the specs on these trucks. My truck the way it was would pull up to 13 psi normally on the highway depending on hills and normally driving anywheres from 5-11psi. If i stomped it I would pull well over 15Psi as the little boost gauge thats installed that is a 15psi gauge will go past and start going around again. I got a lot of questions, but need to start getting some answers for at least a baseline, maybe this thing is out of wack thats why my MPG sucks.
    95 GMC Sierra 2500 4x4 6.5L turbo ext cab 6ft bed ( relocated NEW PMD with cooler, running so far so good) SOLD SOLD SOLD
    95 Chevy Silverado 1500 4x4 Z71 stepside 350V8
  7. #27
    Oct 2003
    Summerville, S.C.
    Cool Mpg
    My MPG averages 14.8
    _________________________
    95 3500 ext cab,K&N air filter
    no other mods
  8. #28
    Dec 2006
    Absarokee, Montana
    Default Mileage - 93 GMC 6.5 Turbo Diesel
    I have a 93 GMC 6.5 Turbo Diesel with a 5 speed manual transmission and I use the criuse control. This is an extended cab pick up approaching 70K miles.
    This is my first diesel vehicle and I am learning the ropes and I really like driving this truck. I live in Montana and it makes going from point A to point B quite pleasant since these points can be very far apart.
    On a recent trip to Minnesota in January, I average 24 mpg. I did have a tail wind that helped and I was traveling light. I normally average better than 20 mph.
    I check my mileage at every fill up, so my mileage records have a good track history. I will see in better detail how things shape up when it warms up. So far winter weather has not slowed me down too much.
    I enjoy this website and bulletin board. Keep up the good work; all the best.
    GMC-RKL
  9. #29
    Dec 2006
    Absarokee, Montana
    Default Tire Size Can Make a difference too.
    I had original rubber on my truck when I received it. The tires quickly played out as I started driving it over Montana gravel roads.
    I replaced the old tires with Cooper 235/85 R16 10 ply. They are taller tires. Over 100 measured miles the odometer is reading about 95 miles traveled. I would imagine I am rolling faster than my speedometer indicates as well. But in Montana the Interstate speed limit is 75 mph. I ususally do not go that fast.
    So, if I could have an accurate measure of miles traveled I might be getting even better mileage than I calculate.
    My truck runs like a dream at 1800 rpm in 5th gear going about 65 mph, and I fit comfortably in it to boot. Happy driving.
    RKL
  10. #30
    Jun 2006
    93 MECHANICAL ext cab long bos 5sp 4x4. Put on the cold air intake, 3in down pipe and 4in exhaust and get 18.5mpg. Have 4:10's
    93 chevy ext cab long box,
    6.5 turbo diesel-4x4-5sp manual.
    186k miles. Cold air intake,
    4in exhaust.
  11. #31
    Apr 2007
    West Michigan
    19 to 21 given the following makeup and variables at approx. 70mph
    Stock 6.5, 4L80-E, 4.10 gears, Stock size tire
    1. 1996 Chevy Suburban
    2. 2500 2wd
    3. Fuel Additive: PSP @ .45 oz/gal
    4. Condition of vehicle: Fair
    5. Driving habits: Conservative
    6. Thermostat: 195
    7. Overall rear gearing: 4.10
    8. Stock Air Filter
    9. Intercooler: None
    10. ECM Boost Control
    11. Stock PCM
    12. Exhaust: stock
    True Americans - Patiently waiting for the poison shrub to burn out.
  12. #32
    Default Has that shrub burned out yet? Soon I hope.
    I'm getting about the same mileage,
    100000 miles on truck
    1995 4x4, K2500
    Stock with a FSD cooler
    and straight through 3" exhaust.
    I plan on putting a 40 horse chip in and am wondering what that'll do to my mileage. Also will be installing after market intake filter (cone style) I want to hear the turbo whine.
    Right now I get 18/20 MPG at 1900 RPM which is about 61MPH.
    Anything over 2000RPM and the gauge drops proportionally.
    What I don't understand is how can a person with a lifted new 4x4, oh let's say a Ford F350 Crew cab just for kicks with a diesel can haul down the freeway at 80MPH and not be in the poor house. I see it all the time.
    I've got a good job make good money, these guys must be running the credit up at the gas station.
  13. #33
    Sep 2006
    Brooker, FL
    Quote Originally Posted by rustyk
    Things do change - with my replacement Peninsular Diesel AMG 230 HP (custom spec'ed) 6.5L TD, mileage is nearly 11 mpg...
  14. #34
    Nov 2001
    Aitkin, MN
    Good Day!
    I hope you're not unaware of it, but going from 9.8 mpg to 10.8 saves you ~ 1 gallon per 100 miles. Do the math: at today's fuel prices, that's a significant savings.
    Blessings!
  15. #35
    18 MPG. That's not bad for a tank.
    94 Silverado 6.5TD Crew Cab DRW
    7" Fabtech Lift / 33" Mud Terrains
    SSDiesel Cold Air Intake and Exhaust
  16. #36
    Aug 2006
    California
    Freeway: 13 to 14 mpg cruising at 75 mph.
    City: 12 to 13 I think my dear wife likes to hear the diesel roar as she leaves the stops. :-)
    4.10 rear end
    Automatic trans.
    Steve
    The Family Truckster is:
    1996 6.5L TD K2500 4x4 Suburban
    Stock except for:
    - Nerf bars
    - FSD Cooler mounted remotely
    Summer '07: 180K miles and going onto my fifth injection pump (first one I've had to pay for)
  17. #37
    Oct 2007
    Gridley, CA
    I have a 94 with 152,000 miles on it with no motor work. The truck is an ext. cab long bed, 3/4 ton with 3.73 gears. Everything is stock except a Heath Diesel lift pump. On freeway I get an average of 22 mpg and in town/highway i get an average of 17-19 mpg.
  18. #38
    Default 94 6.5 Fabtech Lift
    To "dually0815".........Youre truck looks awesme,was wondering if i could get a few pics emailed?Just purchased exact truck and would like to do the exact lift and size tires..Good Looking Truck!!! Thanks, urcableguy@hotmail.com
  19. #39
    Oct 2007
    Lansing,Michigan
    Default My 2 cents on mileage
    1997 Suburban
    1500 1/2 Ton (snicker snicker)
    6.5L factory engine NO mods
    3.42 gears
    42 gallon tank
    150,000 miles
    highway 24mpg @ 65mph
    city 15 - 18mpg depending on season
    Not bad for something that weighs as much as a semi
  20. #40
    Jul 2003
    Broadview, MT
    gets 16-18, doesnt matter if it is in the city, on the highway, pulling, towning, loaded, i hauled a 450 gallon water tank all summer, avg. 16.4, 4.10 gears, but I only drive the truck 63 mph, on the freeway i go 70.
    94' GMC K2500HD, Heath chip, -1.94, Turbo-Master, AFE Cold Air Intake, Bosch High Flow Injectors, 3" Exhaust all the way back, 4.5" chrome tip(exhaust sounds sweet), Heath Turbo Down Pipe, Heath Crossover, IssPro gauges, Three Pod Piller, 98' Cooling Mods, DMax Fan, High output water pump, DSG Oil Cooler, Heath PMD kit, Light kit with high output bulbs(very bright...finally)
