Results 1 to 13 of 13
Thread: I've probably lost my mind
    Nov 2017
    Cantonment
    A gear driven Transfer case would take the abuse and would be strong enough, chain drive will have issues and oil problems.
    I honestly would look into custom gear boxes, and redirect power units.
    I wish I could offer more help, but I think you will be opening a can of worms trying to convert a transfer case.
    Very cool idea!
    However, I'm afraid that the front diff from a 1 ton truck would not be strong enough for full time use lugging around a motorhome. The front diffs were never intended to be used for full power, only when split between the rear and front diffs for part time use. Think of it this way: in a 4WD 3500 truck application, the rear diff would usually have a 10.5" to 11.5" ring gear, while the front diff would only have a 9 to 9.5".
    Having said that, I'm not sure what size the original Toronado "ring gear" is, but chances are, whichever engine you swap in will have more power output than the original motor had, so it would probably need a beefier drivetrain anyway....
    What's so bad with the Toronado setup anyway? My dad is actually using that TH425 tranny/transaxle in a project he's currently building: a 1964 Corvair that will be converted to a mid-engine Chevy 350.
    Apr 2004
    Ottawa, Ontario
    Quote Originally Posted by Rumpelstiltskin View Post
    I agree. Atlas apparently makes a gear driven TC that is built to stand up to 700 ft/lbs or better. However, would have to see how they configure the output shaft bearings etc. Probably not intended for full time front drive only.
    Very cool idea!
    Not too concerned about the diff. My "B" and "D" body cars had 9.5 diffs and I have seen them built to significant specs. The 1/2 shafts on the 3500 are beefier and the output shafts also seem to be heavier.
    My issue with the original setup is that the newest 425 available would still be over 35 years old, plus does not play well with the newer engines. Loved the older torgue monsters (the original Olds Toronado 455 was rated for over 500 ft/lbs.) but again they are also over 40 years old.
    The reason I want to go with the swap over to the 3500 subframe is to allow me to go with newer powertrains and more substantial suspension bits. Just going with the newer unit front wheel bearings is reason enough. Better brakes, heavier torsion bars, etc. make for a better setup. The original GMC motorhome weighed in at 12,500 lbs. I assume I will be adding another 1,500 to 2,000 lbs with my modes. Well within the specs of a 3500.
    I am going for reliability here and the ability to get it fixed when on the road. Finding a good used 425 in a junkyard while 2,000 miles from home is not my idea of a good time.
    Thanks for the input. Finding the right transfer case is still my primary concern.
    Bill
    94 Cadillac Fleetwood (sold)
    08 Aerolight 23TT
    Atlas is a standard in the off-road world. TWF is another: http://www.trailworthyfab.com/Hero-Transfer-Case/
    I know they’ve built some transfer cases for custom applications such as 6x6 and such. They could likely build something for your requirements.
    The other thing to consider is a high pinion front axle so that you’re operating on the drive side of the gears. A low pinion axle in the front is operating on the coast side of the gears - similar to a low pinion rear axle operating in reverse. The downside is that the high pinion axle will likely create some driveline clearance issues over a low pinion axle.
    Diesel Page Member #2423
    Apr 2004
    Ottawa, Ontario
    Quote Originally Posted by trbankii View Post
    Good point about the high/low pinion. Never thought about it but you're right, it would be a consideration.
    TWF is interesting. Wonder if they make a single speed TC. Either that or a 2 speed with OD? Would open up my trans selection to allow for a low speed/high torque engine. Actually considered an LS gas option but they seem to want to see reasonably high revs to achieve the peak torque numbers. As the engine essentially sits beside you in the GMC, noise is certainly a consideration.
    Thanks. Obviously needs some more thinking before pulling the trigger on the project.
    Bill
    08 Aerolight 23TT
    Dec 2003
    Yukon Canada
    Hi Bill
    I am sure that i read about someone using the Olds trans axle on a Dmax in the same motor home as you are looking for.
    Might be worth some time searching the interwebs.
    Apr 2004
    Ottawa, Ontario
    Hi Bill
    When I first started thinking about this, that was my first option. The 425 trans is essentially a turbo 400 with the torque convertor and the front pump split off the main body and a chain drive transferring power to the forward oriented main trans body and thus to the front diff (bolted onto the tailstock). Built like the proverbial brick outhouse but lacks things like a lockup convertor and maintains the original gearing of a 400. The first Toronados (1968) had the circuit built into them that used the dual range torque convertor (giving you effectively a 6 speed trans) and the newer 425 can be built to accept it but finding that convertor would be an issue.
    A simple adapter to convert the BOP bellhousing to the Chevy bolt pattern is required plus modification is required for a different motor mount arrangement (single front mount with two mounts on the back of the trans) and a different flywheel to accept the 400 convertor. Don't know if the trans would hold up to a Duramax over the long haul plus as I mentioned before, you would be starting out with a 40 year old transmission with limited parts availability.
    The age of the components that would have to be overhauled, plus the uniqueness of the various powertrain and suspension parts is what got me thinking of the 3500 subframe and modern parts to update what was actually a brilliant design for a motorhome.
    Bill
    08 Aerolight 23TT
    Quote Originally Posted by convert2diesel View Post
    I had asked Todd about OD options and there was some reason that wasn’t possible. But I seem to recall a project with a single speed transfer case for a project - possibly military.
    Apr 2004
    Ottawa, Ontario
    Obviously some more digging is required. May have to go with a 2 speed and just lock it into high range or tighten up the ratio split to give it some advantage from a standing stop. Going to have to get under the crewcab with a tape measure and see how much room I have for another diff in the front now that you have added that issue to the list
    Thank again
    Bill
    08 Aerolight 23TT
