Thread: fuel sending / pump replacement 06 ??
    Dec 2005
    Klamath falls/keno Oregon
    Default fuel sending / pump replacement 06 ??
    I need to drop the tank, my bed is way full of work related crap..any links??
    Hummer wheels :^)
    dual lift pump
    Banks air intake
    Dec 2005
    Ok then...
    Hummer wheels :^)
    dual lift pump
    Banks air intake
    There is no pump factory. No pump unless someone added it. Look in left rear wheel well area for an added pump or filter.
    Relatively simple project. Remove rear driveshaft for access. Remove attach screws at filler neck. Remove ground strap from bed mount on frame. Rear diff vent also clips to the filler hose.
    Remove straps and begin to lower tank. Unplug sender and lines at top of tank. less fuel is better and remember when you tip the tank the fuel sloshes and it gets way heavy on that end.
    Do a lift pump while you are at it. I'd recommend my twin deluxe kit.
