TheDieselPage.com Forums
2018 - TDP's 22nd Anniversary
Go Back   TheDieselPage.com Forums > The Diesel Page Member Forums > Updates & Announcements
Updates & Announcements What's new in The Diesel Page. New article announcements. Bulletin board login, access & security information. Forum rules & registration info. Web site recommendations and discussion.
Reply
Thread Tools Display Modes
  #1
Old 06-08-2017, 12:26 PM
More Power's Avatar
Administrator
Arrow Rust - Protecting Your Truck
Rust
Protecting Your Truck From Rust
Rust... Every year, millions of vehicles suffer many more millions of dollars in damage due to rust. As awful as the cosmetic damage is, rust can even make your vehicle unsafe to drive and you may not even be aware of it. I don't know of a single instance where someone dismantled their truck, sandblasted-stripped-repainted-recoated the metal parts and then reassembled everything to correct the damage caused by rust - just not worth it. What we'll do here is show you how to easily and inexpensively treat this rust problem. Now available to subscribers in the Member's Area.
Not a subscriber? Visit this link to see how easy and inexpensive it is to become a subscribing and supporting member of TheDieselPage.com.
  #2
Old 06-23-2017, 06:50 AM
Kennedy Kennedy is offline
Your 16 yr old rusty frame looks like 2-3yrs here in the rust belt. I have the inner panels on my trucks coated from new. A good friend of mine does it. He uses a material by WK products called seal out. For lack of a better description it kind of looks like a fancy mustard when sprayed in. It wicks into the crevices and displaces moisture. Being a fluffy paste type it hangs around so you don't have to worry about washing out.
I recently had a truck come in that was freshly done by a Krown oil franchisee. They use a method similar to your article, but they want you back in annually to replenish what migrates.
Another popular product is called Fluid Film. I just recently started using this for spot applications.
Fortunately for me, my radiant floor heat has my buildings warm and dry so the exposed parts don't get too scaly.
__________________
  #3
Old 06-26-2017, 12:02 PM
More Power's Avatar
Administrator
Thanks John.
I may do another article before long that discusses how to prepare a new(er) vehicle for the long haul by using one of the pro undercoating methods, like you ones you mentioned, and include Ziebart and possibly other dealer-applied under-coatings.
If anyone has experience with another pro-applied under-coating that they like, let us know.
  #4
Old 06-27-2017, 10:33 AM
ToddMeister's Avatar
ToddMeister ToddMeister is online now
Moderator
Arrow Rust-proofing on my 2016 LML
Back in April I had my 2016 GMC LML rustproofed at a local shop that has a fine reputation in the area for quality product and workmanship. They are very busy - I had to wait about 4 months to get the truck done.
The name of the shop is Henderson's located in Midland, MI. They use a product similar to Rustproof Compount L made by Texaco/Chevron. It is a mineral oil based product thinned with Stoddard solvent for spray application.
__________________
2016 GMC SLT 2500 CC 4x4 Duramax All Terrain 12K
1995 GMC 2500 EC 4x4 6.5TD,213K,Custom Tuning,HX40W-II turbo,Amsoil Bypass Filter,KD Exhaust,FSD Cooler,KD Headlight booster,Hi-cap Cooling
TDP member #14
  #5
Old 06-28-2017, 10:06 AM
More Power's Avatar
Administrator
Thanks Todd,
The under-treatment your truck got sounds a lot like what I do.
My truck's frame and drivetrain were originally undercoated at the factory. Over time, the rough & thick coating began to peel in places, and since the thick coating was sprayed on it didn't wick into/onto other areas beneath the truck.
More than a dozen years ago I got a phone call from a fleet mechanic in the upper Midwest who told me during our conversation that they spray a solution beneath their trucks and service vehicles every year, as part of an annual rust preventive program.
I'll have to replace a couple of the 4" exhaust system clamps this summer because even though the aftermarket exhaust system is stainless-steel, a couple of the clamps are mild steel and could fail because of rust.
  #6
Old 10-05-2017, 07:40 AM
Had a customer in with a truck that he has done annually by a Rust Check franchisee. Something like $140/application. Personally, I would probably look at having the rust check done first year. Second year I would investigate how the WK product did for inner panels and have the rust check done externally.
http://www.rustcheck.com/
__________________
  #7
Old 12-09-2017, 07:47 PM
gary_lucas's Avatar
gary_lucas gary_lucas is offline
Enthusiast
I was about to spray my truck under body tomorrow, when I was re-reading the article and saw it recommended used crankcase oil.
I've got used rear diff oil and used trans fluid. But no engine oil, any reason why I might want to NOT use the dirty rear diff oil and diesel?
I know it's a bit smelly but I assume that'll just dry out.
I could go buy some fresh oil but seems a waste.
Thanks!
Gary
__________________
  #8
Old 12-11-2017, 01:00 PM
More Power's Avatar
Administrator
Thanks!
Gary
I think any oil is likely OK. Used diesel crankcase oil is usually some shade of gray/black, which adds an undercoating look to it.
Just go easy on the application. It should not drip.
  #9
Old 12-13-2017, 10:11 PM
gary_lucas's Avatar
Enthusiast
Thanks!
I ended up buying a couple containers of fluid film and I used that on the running gear side (apparently it's less likely to interact harmfully with the rubber components).
I'm going to spray the rest with gear oil and diesel tomorrow.
I seriously considered getting a krown type application as this truck hasn't been treated in years and presumably a shop with an air gun and a lift would do a better job than I could... But ultimately there's no one in the area who does an oil based undercoat, they seem to only do the tar substance as far as I can tell.
__________________
  #10
Old 12-14-2017, 10:14 PM
gary_lucas's Avatar
Enthusiast
Thumbs down
I started out with the intention of using gear oil and diesel. But once I opened my used gear oil I couldn't stand the smell and gave up.
I ended up doing a light spray of fluid film underneath the truck in all the sketchy areas. I paid particularly close attention to the fuel tank straps as I've already had one corrode and fall off. The other one seemed to be in good shape so I sprayed them down.
I called my local dealership and asked them about their undercoat options and wasn't overly impressed.
Black tar... $700
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
