TheDieselPage.com Forums
2017 - TDP's 21st Anniversary
Go Back   TheDieselPage.com Forums > The Diesel Page Member Forums > Updates & Announcements
Updates & Announcements What's new in The Diesel Page. New article announcements. Bulletin board login, access & security information. Forum rules & registration info. Web site recommendations and discussion.
Reply
Thread Tools Display Modes
  #1
Old 11-14-2016, 02:01 PM
More Power's Avatar
Administrator
Arrow Duramax Water Pump Replacement - Part I
We're here to save you money and provide the information you need to do the best job possible.
Own one of these trucks long enough and you'll eventually be faced with the prospect of replacing the original water pump. Normal cooling system pressure is in the range of 8-10 psi. The water pump's coolant-side seal is there to contain this pressure against a spinning shaft. Over time, this seal will wear until it begins to leak coolant. That's your cue for a need to install a new pump. What we'll do in this two part series is explain how to correctly identify a leaking water pump seal, give you a list of part numbers you'll need for the new parts, identify the special tools you'll need, and show you how to do the work using large clear photos and easy to follow instructions.
  #2
Old 04-12-2017, 01:56 PM
More Power's Avatar
Administrator
Duramax Water Pump Replacement - Part II
Do the Best Job Possible
In Part II I walk you through the process of replacing the Duramax water pump using the best tools, methods and parts. Everything you need is included... except maybe elbow grease. Do it right - learn how here. Now available to subscribers in the Member's Area.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
Copyright 1996-2017 by TheDieselPage.com - All Rights Reserved
