TheDieselPage.com Forums
2017 - TDP's 21st Anniversary
Go Back   TheDieselPage.com Forums > The Diesel Page Member Forums > Member's Forum
Member's Forum The Diesel Page Member community forum. General discussion forum for topics not necessarily focused on diesels.
Reply
Thread Tools Display Modes
  #41
Old 08-28-2017, 06:08 AM
Robyn's Avatar
Robyn Robyn is offline
Missy Good Wench ( Moderator)
Just did a Google search for hot dip galv, and there is a plant less than 10 miles from here.
I am going to take the new brackets to them when I get the fab work done and get a quote to have them dipped
With the weather we get here this is sure a great idea.
Thanks for mentioning it.
Paint is so so, but during assembly it can get scratched off or dinged, and then rust will start.
__________________
(1) 95 Suburban 2500 4x4
(1) 2017 Mercedes C class
  #42
Old 08-28-2017, 01:43 PM
a5150nut's Avatar
a5150nut a5150nut is offline
Enthusiast
I thought of the hot dip because we build some base plates for a precast concrete outfit once. They sent them out for hot dip and when unloading them at their yard the 1 in rebar started snapping off of the 1 1/4 plate base. When they called me over all upset I asked "Was that grade 60 rebar weldable or non?" Quick trip to the engineer and he didn't know there was a difference. Instead of their guys torch cutting the next set we saw cut them and used weldable grade 60 with no more problems.
__________________
-Patrick Henry
A5150nut
2006 K3500 D/A
94 6.5 4x4 5spd Sold
  #43
Old 09-05-2017, 07:08 AM
Robyn's Avatar
Hmmmm
Engineer had no clue. Bummer.
Well the project is winding down now.
The bulk of the work is done and I replaced the last of the Cedar boards on the East West long run right near the area of the beam replacement.
Working on an area on the corner where a bit of additional flashing was needed.
Would have been way better had I realized the issue back in 1993 right when they were building the deck.
But happily no serious damage was found.
Better yet NO BUGS
__________________
  #44
Old 09-05-2017, 07:41 AM
gary_lucas's Avatar
gary_lucas gary_lucas is offline
Enthusiast
Making a note to read this thread carefully. We were going to do some decking this summer but got waylaid by head gaskets and a ton of other things.
Thanks for documenting your experiences!
__________________
  #45
Old 09-05-2017, 08:11 AM
Robyn's Avatar
Hope it helps.
I wish the $$$$ were there to have torn the entire deck off and started fresh.
Things would be waaaaaaaaaaaaaaaaay different.
Bigger, more stairway access and the East West run would have a rain bib under it to shelter the lower entrance doors.
Sadly though the cost of fixing the well/pump back in March hit me in the $7 K range.
The deck is structurally OK, just needed a bunch of long overdue maintenance.
Always easy to see the mistakes looking back... the 20/20 hindsight ya know.
Happily the overall project (House build) was good and has been a great place to live now for 24 years.
__________________
  #46
Old 09-05-2017, 09:10 AM
trbankii's Avatar
trbankii trbankii is offline
Enthusiast
Quote:
Any rebar is going to have a fairly high (relative) carbon content and require low hydrogen electrodes and pre-heat at a minimum. ASTM A615 steel for Grade 40, 60, & 70 has no upper carbon limit, so that might be what you mean by “non-weldable.” ASTM A706 has a maximum carbon equivalent of 0.55% and is available only in Grade 60. To provide excellent weldability, you’d want less than a 0.14% carbon equivalent. So you’re going to want to have someone who knows what they’re doing even to weld ASTM A706 rebar.
Typically, you should be spec’ing studs rather than trying to weld rebar to things.
__________________
’94 GMC 6.5TD K1500 4L80E Yukon SLE 214K
’93 Chevrolet 6.5TD K2500HD NV4500 Std. Cab Longbed 183K
’85 Toyota 22R RN60 4x4 Std. Cab Shortbed 178K (Currently retired for rebuild)
Diesel Page Member #2423
  #47
Old 09-05-2017, 04:27 PM
Robyn's Avatar
Aside from the tools and the temporary lumber piled all over the job is about done.
Need to replace the two corner trim boards where the pressure treated and cedar join on the SE corner.
Pix 41 shows the area well.
Still have a tid bit to do on the Galv corner to fit an end plug in to keep water out.
The #1 board under the brown flashing is a plastic board.
Added that flashing several years ago to keep water away from the siding.
I have some dandy dry 1x4 cedar that will fit nice.
I want to cover the corner flashing and calk it well to keep things dry.
The south side gets hammered by the weather real hard.
Stuff is in sketchy shape and I cut them up to allow the flashing to fit.
Piccys
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
Copyright 1996-2017 by TheDieselPage.com - All Rights Reserved
